It rides so light compared to the ascender at least, I don’t have a lot of time on a khaos but some. I kept thinking all day what if it had the 858 power, going to be crazy good sled I’m sure! I also was pulling every line as my friends with the 800s and 850s, just slower track speed.Great news! I'm even more excited to get mine. If it's as good as I'm hearing, my Khaos may be going away.
I can’t speak to the catalyst with its extra short tunnel, but cat has been running the short front mounted cooler since 2013 and it’s been fine as long as you run scratchers whenever in lower snow conditions. I’ve never had heat issues on my short cooler cats unless it was rock hard snow and every brand was having heat issues, and I don’t run a snow flap.Let's just hope it gets more snow from the stiffer Power Claw track. That could make all the difference.
Where did you take 3.5” from?I cut 3.5" off all my ascenders and they don't overheat with proper management
I was thinking you cut 3.5” from the heat exchanger but that’s unlikely. 3.5” off snow flap makes more sense. Plus, you called it heat management so that right there tells me your a tardWhere did you take 3.5” from?
3.5” from the tunnel ya tardI was thinking you cut 3.5” from the heat exchanger but that’s unlikely. 3.5” off snow flap makes more sense. Plus, you called it heat management so that right there tells me your a tard
weird. Dude can’t ride worth a smit. No need for a tunnel cut3.5” from the tunnel ya tard![]()
Come ride with meweird. Dude can’t ride worth a smit. No need for a tunnel cut
