Yes, that is correct. From what I can tell you can just leave it activated (Green) as you can set up and leave the gauges alone if you chose to. I really like how you can display pretty much all your pertinent info on one screen without having to toggle around. It's a nice feature, and the more I play around with the G8, the more I'm glad that I decided to spend the $ for the Mountain Cat.As with previous ATAC sleds, you activate it by pushing the center of the top button on the left, then can scroll left or right to set the dampening. I am guessing with the G8, you can just leave it activated. I always turned mine off after adjusting so I could see my temp gauge.
One thing that I found out though is that if you do a map update, it takes a REALLY long time, so make sure that you have a fast internet connection. In my case I had to park the sled in my yard so that it was closer to the router in the house. Also, I temporarily changed the screen to sleep time out to 30 minutes so that I could periodically tap the screen to see the download progress bar.
Additionally, I plugged in the USB charger so that the unit's internal battery was fully charged.
