Sled was hand made with all the best parts Van Amburg tunnel extension with full length heat exchanger.EZ Ryde long travel suspension with adjustable remote reservoir shock.Track is the Arctic Cat 153 x 2.25 Attack along with Wahl introvert/extrovert drivers Motor is the IQR bottom end with the 800 twin mono block Cyls and pistons.Power Addiction Racing heads with 13:1 domes that run on 110 octane fuel.I also have lower compression domes from PAR to run on 93 octane but the lower octane could be used as is with timing retarded
down to G.I installed a Holtzman Altitude Temperature Compensator which has worked flawlessly.Twin pipes are chrome plated and were purchased from Power Addiction as well. Digatron unit for exhaust and coolant temp.Fox Float Evol front shocks and Polaris gripper skis.I currently have wheels on the front spindles to make it more easily to move.Front suspension is from Zbroz.The sled has proven to be solid,reliable,gobbs of power and torque and so fun to ride.Comes with some extras like spare stock Dragon control arms spare track and Polaris Factory cover.Selling only because of health reasons and the sled deserves to be ridden and enjoyed.Located in Livonia Michigan
