Thought I was the only one who thought that thought. HahaThe alpha rail is a failed experiment imo.
I think that’s roughly where the long estart seat is and the shorter non estart seat is slightly more.how much fuel does the current ascender hold i saw the catalyst is showing 10.4 gallons.
Now you should get it. You're not willing to settle for an alpha rail but expect people should settle for a 600. Maybe that alpha rail will make you a better rider.The guys who are most adamant about needing a 800+ are most likely the ones who need it the least. I can not tell you how many days I’ve spent babysitting grown men on 160”+ 800’s while I’m on a 600 144” Iqr breaking trail, telling them what lines to take and to not follow mine(cause they’ll get stuck). Most are flattering themselves thinking they need what they have when a 600 would make them a better rider but whatever, big hp and dreaming to be able to do bowties is what sells right now. It’s no different in the dirt bike world, everyone wants a 450 or 300 and they flounder in the C class.
If I can snowcheck a twin rail I’m getting one, no twin rail option and I’m not interested. The alpha rail is a failed experiment imo.
The distance between the upper and lower ball joints is different.settle? like youre going to buy this sled or youre not riding Mr! LOL
wonder if their new spindles will work on older chassis, they look much much better than the current riot spindle.
There's a little bit of new info on the website: they're still calling the 600 a 125hp engine.
There was speculation, but it seems that 10% weight loss is true. That is going to be very significant. I'm seeing that the current 154" Alpha Mtn Cat is 437lbs. A 10% reduction puts it under 400lbs.
Here's some screenshots or you can go to the Cat site and play with their graphic yourself.
First off i don't know the hp of the 600, 140 was a guess maybe its more maybe its less. As for it not being enough how would you know without riding it?
Here’s what the paperwork for my estart ‘20 says for weight, but who knows how accurate it is considering they don’t even have accurate track lengths for the alphas on there. If the 10% loss is accurate it should at least put them comparable to Polaris which seems to be the limit for durability considering how the poos have been gaining weight and I believe the xp doo did the same thing when they shot for light weight then had to add it back.
Numbers don't seem too consistent, I'm seeing several sites listing 437, and others saying 446 (non e-start). 10% off 446 is 402lbs. Even using 460lbs to start with, 10% puts it at 414lbs which is lighter than Matryx sleds. Guess all we can do is speculate until we see one on a scale a year from now.The 2018 153 Cats weighed 457 dry. I could not find anything more recent that was official.
