I Have been following this thread I brought pcv from jim running it on ported m1000,have it running well did not know when in auto tune trims where adj as you run, i thought you had to save them then go run again. But my ? is has anybody auto tuned sled at 1500 feet then went up to 8000 + and did tuneing stay or do we have to auto tune at 8000 feet also
According to Jim, the PCV map will work at any elevation because it adds or subtracts fuel from the sleds map which self-compensates for elevation.
I believe there is some risk in reducing fuel at lower R's. The factories are building a fuel system that has to be as lean as possible yet not create burn down...not always successful. I don't know about Cat but Polaris has a set of low speed and another set of high speed injectors. The injector transition has to correlate with the EV function or you can get a lean bog or mid range stumble. You have different spring rates on EV's that change when they open and also clutching can play a part since the ECU monitors various sensors and adjusts fuel and ignition advance. A solenoid controls when the EV's can open. At WOT it's a no brainer but at lower R's you can easily get too lean and off throttle the deto sensor may not save you. It's possible to be loafing along on the way back from a ride with the EV's open or the EV's closed depending on clutching, EV springs, and even snow conditions. I've experienced that condition on my sled, I can vary RPM as much as 800 R's running the same speed just with clutching (loafing along back to the parking lot). The fuel delivery and ignition advance have a lot more variables now (than in the carb days)and they will have a lean bias at low R's to meet EPA emissions. The factories don't publish these parameters and change them as they try to make improvements.
I'd like to know more about this. I like the top end, but was looking for a little more hit down low. I thought I would lean the bottom ever so slightly to see if it made a difference. However, I was going to do this map on a switch so that I can go back to my everyday map to get rich as needed.
If you are looking for more torque and throttle response in the midrange I recommend adding fuel. If you watch your AFR in the midrange you will see that the factory already leaned them out as far as possible sometimes 15:1 or 16:1 (for emissions not power). Add fuel untill you hit 14.0 -14.5 in the midrange and you will gain power and throttle response.
If you look at a map built by SLP or Dynotech you can see that both maps have added fuel in the midrange for the Polaris Dragon 800.
What mods, full pipe set etc?got my PCV from Racinstation , he included a map for my specific mods and said he would help with future maps if i needed.
anyhow after going out one trip with a bd box i was not even close to tuned , tossed in the towel on that and put in the PCV. pluged it in and the map was awesome. no muss no fuss , just riding.
Racinstation made the maps for 1000s recently and i can tell you it made my sled rip. no more mid bog !
D they make these for the RT 1000
