F
flatfoot
i rode today and finally got some trim numbers. i can tell it is working better, getting higher rpms. but still 100 % throttle it has hard time holding 8100 likes to fall to 7700. at 5000 rpm to 8400 0 - 60% throttle at 13.5 then at 80% throttle 13.1 and 100% 12.5 the last trail run (right before ran out of gas) sled hit detination!! is 12.5 to lean?? tested 6000 ft and was cold 7 degree F. usaually ride 7 -9500ft. should i have the same air/fuel ratio thoughout the entire powerband?
ummmm, might want to figure out the difference between rich and lean before you try to tune. 12.5 is to the rich side of things, optimum a/f ratio for EMISSIONS is 14.7/1
