DTR has different fuel maps for the "update" flash and the January reflash - the "157HP" map is intended for the "update" reflash, the "156HP" map was for the January reflash (post update). The 2 maps are noticeably different, but mostly in the low to midrange. I don't know if he has any full map posted yet for the April reflash, but has mentioned that WOT fuel calibration wasn't changed significantly vs previous maps. As always, there is some variation in how individual sleds respond, so some custom tuning may be needed.I am assuming here but I think you 156 map is just a little richer map than the original 157 map. I would ask Jim himself if you really want to know the finer details. Jim is a great tuning resource for this stuff.
My suggestion is try it out and see how it runs. Don't forget to run good premium fuel.
i have tuning info on cfi4 sleds with slp twins and head work if anyone wants them. also have a PCV with autotune for sale... practicaly new
I guess I'm a little confused...
So what is the point of tuning to an AFR using the auto tune? If you still have to use trial and error to get the proper AFR using the auto tune, why bother? I could understand if there was a uniform ratio that worked for all rpms but there isn't...
May as well save the cash and tune by percentage with the base module...?
The auto tune will hit your targets it's just that there can be an off number in a spot or two. The atune just compensated for a condition like a rapid throttle movement or such. Then you go in and change those.
If you want to tune the pcv with plug and piston readings only the big trick is to know what the throttle percent is so you adjust the right cell in the pcv. Also it's good to know the various tp and rpm combos that you will hit according to your particular riding style and conditions. An lcd display will help a lot but it will still be a huge amount of work/time.
The atune is just easy by comparison.
