Beautiful looking sled Flit-e...but your not done yet...you need to hit Rob up for a set of his better boards...otherwise she looks ready to rock...
Ron, Wyoming metal art did my powder coating
I've had it for a while, but probably got it at an automotive parts store or Schucks.Ron,
Where did you get the toggle switch that you installed.
Lano
Here is a picture of an older thermostat (left) and the one off my 09 (right). Note the larger bypass hole on the 09-seal is on the far right.
I am going to try this modified thermo, since it was an old one I still have the stocker to put back in if I don't like it. Cold running boondocking it may run too cold without the thermostat. Left just the top arch to add a little turbulence to the water flow.
Found a larger bottle (6 oz at Target) to catch oil draining from the exhaust valves. Replaced the stock drain line with a longer one, added velcro to the bottle and to the bumper strut & tied it off with a velcro wrap. The top of the bottle is open so that there is no back pressure on the drain line. Have not done this before so will just watch and see how it works. I will shorten the drain a little after I see how it looks after a ride or two.
Ron. First, cudos to you for your passion to the sport and your build and thank you for sharing! There is no doubt that you know your Dragon's and IQ chassis'. As far as temps go, what should the 800 run for engine temps? My 08 D8 is mostly stock...compared to yours anyway. I think mine was always running a little on the cold side.
Thanks
Ron,
Is there any reason why you could not run that drain line out the bottom say down by the can or someplace that would get it out side of the chassis so you would not have to deal with the bottle?
This is my first Poo Poo and it is still in the crate hoping to get started on it after the Spokane show. Have lots of plans for aftermarket and dress ups. Of course the first thing it will get is professionally installed Better Boards from my good buddy Rob. Thinking about some power coating just not sure about a color skeem yet.
Thanks for all your info you have put up here.
Jay
