R
Ron
ACCOUNT CLOSED
Finally got enough snow for a break in ride today, rode 70 miles on logging roads as much as 14" powder on an old base. After about 40 miles I spent a little time looking for the stumble reported by some-mine has instant throttle response at all speeds. No bog, no hesitation.
Even with extra oil in the tank, the sled is pulling more R's than my 08 did with the only change a port job and milled head. My weights are almost a gram heavier and pulling 150 more R's first tank of gas vs end of season on the 08.
The exhaust valves seem to open at about 7600-7700 RPM's, quite a bit higher than I expected. As I recall the 08's open below 7000. I didn't detect anything adverse with the higher opening level. The transition was smooth unless I eased slowly into the higher R's then I could feel a surge as the valves opened.
As mentioned earlier the belt side clearance on my sled was excessive so I reduced it to .015. This raised engagement by almost 800 RPM (compared to last year) -by the end of the day engagement was down about 400 & engagement was smoother. Don't ask me for exact #'s, I didn't spend much time on it, just noticed it was high. When it does engage the tach jumps making an accurate reading dificult. Conclusion-.015 is too close for my clutch setup but may be perfect after another ride or two. As you adjust the shims under the spider the position of the weight on the roller changes so that the weight has less leverage (in this case). Result is more R's to create the force necessary to move the weight and engage the clutch.
