thank you brycter. I acutally bought a extra set of the turbo reeds just incase. the ones I have in it look perfect though.
have you guys had good luck with the stock reed boots with your girdle on them?
thinking of giving what I have the go and later on getting the boyesen aluminium boots a try. I would have got them in the first place, but was runing low on funds and wanted to make sure I had enough to complete the project.
just looked on boyesen's website and the rage cage just has the piece off the front of it that goes up into the stock reed boots. Does the rage cage with xp turbo reeds only have two reeds like pictured on their site or does it have 4 reeds like stock? I thought they made a aluminium boot to replace the stock rubber/plastic reed boot. guess I will have to call them.
well it turns out my xp has a crack pipe... I mean a cracked pipe.
I didn't notice it the first time I looked at it, but looked at it again just now and noticed that one of the seems/welds is cracked about 12" long. I guess I will call cpi to let them know that their pipe cracked and take it to a local welder to have it fixed along with my oil tank. going to change the oil tank a little so that it is stronger and hopefully does not break again. I had a adapter and had a 7/8" or so pipe off the top of the tank and threaded it into the adapter on the bottom of the turbo. well the threaded part is obviously thiner and it cracked their just as it comes out of the adapter. going to put a solid piece of pipe on this time and have it welded to the adapter. maybee even slide a piece of aluminium in the adapter. then slide the biger pipe over it and weld it all together so it is extra strong. Don't want it to break again. Was thinking of mounting a tank on the sled somewhere below the turbo and connect the turbo and tank with a ruber hose so their is not the vibration and chance of it braking the weld from the tank vibrating, oil sloshing around and bumps all on a rigid piece that bolts to the bottom of the turbo. Can't really see a good place I would like to mount the tank to though under the turbo.
unfortunatly I still need a throttle cable so I will not be riding this weekend. unless by some miracle the dealer has one in stock. going to call tomarrow. I was hopeing to find something other then the $62 stock one, but no one makes one for the xp. spi has one listed in wps. part number 70-1087 with a retail of $16, but it is on backorder untill march. it is also listed as for 09-10 xp so I am not sure if it would work on my 08.
