turbo xp is runing badass!!!
Still trying to get my ducks in a row. The sleds will be there and I'll be there late. Just trying to finish up some things before I leave.
Dave
I agree to each their own!! Guess we will just let the sleds do the talking.;)
You guys are still planning on being in Cooke City?? We will just go pound on these things there.:beer;
Jim, New Hampshire. ( salem ).
Gus
What is the elevation there in Salem???
How often do you go west to the Rocky Mountains?
Have you ever taken one of your turbos above 8000 feet?
I am just curious, not trying to pick a fight......yet:D:D:D
1. 230 feet above seal level.
2. never been
3. only my customers have been that high and higher so far.
4. Only turbo 2 stroke to EVER win the world series of ice, 87 and the canadian world series in 88 and 89. then ISR tossed us out of raicng..1990.
What you guys get to do riding your sleds is awesome. I only wish I was living there too.
In march or maybe sooner I will head out to meet and ride with some of you.
I look forward to it and to riding in real snow !!!
So far the clutching and tuning That those who follow have been using has been really good. don't know what makes some think that clutching and fuel tuning is mysteriously different from flats to hi alt. ( under boost ).
Now all you guys are and have been riding them and making them better than they were in the old days.. MAN thats for sure.
What you don't know is I never stopped ,, I had EFi in 1989 on one open fueler and carbs on the other.
The efi was from FMS ( fuel managment systems). Gerhart maier company.
Even used methanol for a while in 88-89
Do I prefer EFI to carbs ?/
ONLY if the electrical system can support it.
Slowly building a good batch of sleds agin for the pro mod poweradder class and top fuel..
Just finished welding hooker plates to a 144 ,, damn suckkky job !!
Gus;);)
have fun
Cook sounds like alot of fun. I would love to be their to meet everyone else and see how their sled runs.
I didn't have any plans for it though and probably will not go. I try to sled as much as I can, but keep it local to keep the cost down. Their is alot of good riding around here. Praying for more snow right now. :D Bring on the bottomless days. Can't wait.
Well Badass1000, props to you for building your own setup. :beer;
Tell ya what, i've got a proposition. I live in Twin Falls. I'm wanting to go to cooke for this ride, (assuming they have enough snow) If you can make it to twin, you can bail in with me in my rig and and just pitch in a little on the fuel and hotel, hows that sound?
Shoot me a PM if your interested:beer;
sounds good cbx. I got to see if I get my sled fixed and runing by then first though. Thank you very much for the offer.
well.... I got the sputtering and bottom end issue fixed on the 4th day. Yes 4th day and not years. lol...
I just turned the fuel/air screws in a 1/2 turn. I don't know what they were at and it was a pain to do it on the sled with secondary removed. Throttle responce is still not as good at high elevations as it is at low elevations, but it is still better then a stock xp. Still want to play with maybee the pilots to see if I can get throttle responce better at high elevations. maybee play with air screws some more too. also thinking of trying 360 or 370 mains and just opening the power jets more. on 4th and 5th day I did not touch the power jets from 1 turn out from 5,500-+ 8,000' elevation. unfortunatly where the oil tank connects to the adapter on the turbo cracked on the 4th day. tried jb welding it and putting a hose clamp over the crack. tank stayed on, but leaked oil every where. trail was really rough on the previous days and I was really hamering them. skiped trail alltogether on 5th and 6th days after jb welding tank. going to do some thing different so it does not break again. got one idea that should be good, but got another idea that should not have any problems at all. don't want to have to worry about it.
we got pretty deep fresh snow on the 5th day. sled ran great, but still need more power. when ground speed is up it does good, but when you get the ground speed way down and pin it, it just points the skii's at the sky. after awhile it gains the ground speed back and keeps going. I went through one section tight through some trees and slowed way down. I thought for sure I was stuck, but just kept it pined and it crawled along. about a 6' deep trench for a long ways. :D
Can't wait to turn it up to 10lbs on a deep day and try to figure out how to keep the front end down on this 154. for now 7lbs is great on pump gas.
On the 6th day it felt like power was droping, but thought it was because we had alot of fresh snow and it got warm. Snow was really wet and heavy.
started turning clickers up and turning power jets off. Then realized it was only pulling 4 or 5lbs of boost. Checked stuff out and couldn't find any thing wrong. decided I better head back before we have to tow it out. after awhile it wasn't making any boost, but fortunatly was still runing. felt like power was down a little compared to a stocker, but it still ran. So I just took it easy to limp it back to the cabin. checked pipe, charge tube, charge box, rave valves, turbo, waste gate, bov, and couplers and they were all good. Then noticed the throttle cable was frayed bad at the throttle and only a few strands still holding. Wouldn't ride it if I could fix it. Rode the M8 all day on the 7th day. it was fun since I hadn't rode it in a long time.
So I am going to rig something up to presureize the system tomarrow night and see what it is leaking from. got work lined up for all day tomarrow. All I can think of is the carb boots. I would think it would run like crap if it was the carb boots though.
I usually always presureize new installs before runing them to find leaks, but I was in a hurry to get it done and head out to ride. You would be surprised where you find leaks some times.
Can't wait to get it fixed and ride it again. :D
you have failed the reeds, you will find them chipped up or split.
There is a bullet proof fix for them too....
CAT CAGES<<< doubled stock petals, top petal tri hinged to drop tension and increase response..
No engine damage if failed like steel WILL do eventually.. cheap readily availible petals at cat dealers...
the double V cages like the doo and v farce are wrong for turbos, the reed angle is much too flat, the petals are not tensioned ENOUGH during open closie events AND THEY DON"T FLOW anywhere near the air a stock single V cage does ..
That old add hype of 247% more reed tip area is accurate only on paper,, PUT them on a flow bench then smile at what you learned..
single V cages are the correct way to intake a turbo 2 stroke.
Like comparing 4 valve heads to 2 valve heads for a TOP FUELER !!!! LOL
You can buy the cages or petals from me OR I will send a pic of modified stock upper petals for you to copy..
My customers using these reeds have had no failures in 2 seasons at over 20 psi.. its a no brainer,, but seems very hard to pursuade you guys to even try them.. Once the Monkey see monkey doo turbo builders copy me then it'll be more widely accepted..LOL
Seems the aero's are going the way of the dinosour too..:D:D
I will pull it apart and check the reeds. I will probably presure check it first since it is almost all together just to check for leaks anyways.
Then I will have to pull it all apart to replace my throttle cable. :mad:
fraying throttle cable explains why it would hang up and have run on once in awhile. I had my bov working great most of the time and every once in awhile it would hang up and want to keep going and I would have to hit the brakes. cable is all frayed at the throttle lever with only a few strands still holding it.
I hope it is not the reeds. I put brand new boyesen turbo reeds in and they would have failed on the 6th day runing them. not good.
If it is failed reeds I will send you a pm about your reed setup. I don't know about the steel reeds. Don't want to take the chance of ruining my motor and turbo if they fail.
How low on oil did you get, the turbo bearings may have overheated, That will cause the boost to be way low, I have learned this from experience:)
it still had a pretty decent amount in the tank. I have a red led activatied by a hobs switch to make sure oil presure does not drop or run out of oil. I am runing coolant to the turbo. I can hold my hand on the oil tank for a decent amount of time. oil is definatly colder then the oil I run to my turbo bikes.
I set the hobs switch at 5psi and am runing 10w-30 full synthetic mobile one car oil. when I first start or oil is cold the light goes off and stays off. once the oil warms up the light blinks. The pump pulses so the light flashes the whole time. the led is bright, but not too bright:confused: it is a little anoying, but atleast I know if the light is flashing it is working and the light is very easy to see in all conditions. Even with snow on it. :D I am thinking of turning the hobs switch to 4psi or maybee just below so the light does not flash when the pump is working, but will come on if the pump quites or their is no oil. pump is advertised as 4-7psi.
I definatly do not think it is a turbo problem. Turbo spins for a very long time after shuting it off.
I tried runing it for awhile with the water to the turbo shut off. Turbo gets way hotter with the water shut off to it. with water to the turbo if I put snow on the center section it will steem off right against the turbine houseing to about 3/16" away from turbine. The rest the snow just melts off. with the water turned off it boils snow on the whole center section.
Can you give some more details on this switch, part#? My kit has a sending unit connected to an idiot light but the light is always on, it is only supposed to come on when there is not enough pressure. I believe this unit is for the journal bearing turbos that require much more oil pressure.
it is just a hobs switch. it is actually a really nice stainless steel one I had leftover from a aquamist water injection kit. it is a normally closed hobs switch. just run power to one side of the led and run the ground from the led to the hobs switch. other side of hobs switch to chassie ground.
so when oil presure is below whatever you set it at the light will be on. ground will be connected. Then when oil presure gets above whatever you set it at the connection opens and light turns off. sled has to be runing to have power for the light to be on. I connected a 12v battery to prime the fuel system and make sure the oil pump was primed and getting oil to the turbo before starting the sled for the first time.
I could figure out a price for you to get the whole assembly/all the parts you need.
I will try to post pics of everything tonight or tomarrow.
Are you sure you can not adjust the unit that you have now? You can send me a pic of it to: jeremywanders@hotmail.com and I will let you know if it is a hobbs switch or not and if it is how to adjust it.
if it is a typical cheap hobs switch their will be a ruber cap on the top. pull the ruber cap off and their will be a ajuster screw or allen to adjust the presure the switch opens or closses at.
This works great and will take some worry out of the turbo oiling system. But you do have to set your own pressure for your type of oil and oil pump. Each viscosity and brand of pump is differnt. Also you can go to jeggs and get a 6PSI oil pressure switch if you are running more pressure than that.
Great thread! I'd like to start building my own turbo kits as well. Hopefully this summer I can either get going on the my camaro (which has an efi swap) or build one for the Rev.
yes. I could probably dump 20-50 oil in it and the light would quite flashing. I have heard of people useing down to 0-5w oil so it flows easily at cold temps to people useing 20-50 to keep the pressure up.
I just have a bunch of 10-30 mobile one full synthetic in the garage that I don't use in any thing else so I figured I would use it in the sled.
I had a set of 2 stage/stiffer reeds from Boyeson...didnt get to test them...gave them to Jmoore...they work very well vs stock...Not that Gus's trick doesnt work, just the turbo Boyesons are another option...BJ
