I don't post much on SW anymore mostly because of the trolls, but this is a good topic and I will stay in unless it get's out of hand.
The effect of a water to air intercooler is shocking to say the least. Like M5 says, the way that sleds are packaged, and the speed they travel in meadows and trees makes the air to air inefficient.
Here is a good example. Last season I ran my Apex at 16-18 lbs boost pulling full RPM with 94 gr Dalton weights and using a 2871R turbo with air to air intercooler.
I installed the same motor, clutches, track, and turbo on my Nypex and had to turn my boost down to 12-14 lbs to stay off the rev limiter. The sled ran completely different. Throttle response was better everywhere, the sled would never fade on a long pull no matter what the snow conditions.
The only thing we changed was adding a water to air airbox and a snow cooled aluminum gas tank.
The airbox is always cold even after a long pull. It is easily the best mod I have made to a turbo sled. We now use the same design of airbox on our Pro turbo kits and they run unbelievable for a 2 stroke at only 8 lbs boost.
We built a water to air for my Nytro, and same result. I had to turn the boost from 16-17 lbs down to 13-14 lbs.
Every airbox uses a closed loop design heat exchanger and a small electric water pump to circulate the coolant.
Thats impressive
Neil would your water to air intercooler be able work on other turbo kits? Say MCX or Impulse?
