Now waste gates.
Garrett has a pretty nice description with pics saves me a bunch of typing. The Mitsu wastegates are bascally the same as the Garretts. You see this question come up a lot of the times by newcomers to turbos "How do you adjust the boost on an MCX kit?". Can it be done, well yes it can. The waste gate on a Garret or Mitsu turbo is held in place by a spring loaded pot. The spring provides a range of available boost from 0 lbs to whatever. So basically all a boost controller does is spill air within the limits that the spring is set at. So if you want more boost shorten the length the wastegate rod thus increasing the spring tension, less boost make it longer. An automatic boost controller and a manual boost controller do the same thing, they its just that the automatic one is tied to baromteric pressure (pressure equals elevation) thats how it can alter the peak boost, with a manual contoller its up to you to adjust the boost for elevation, totally the same deal neither determines what your peak boost is set at they just allow you to adjust it wintin a set range depending on the controller.
http://www.turbobygarrett.com/turbobygarrett/wastegates
M5
M5
