Just wanted to provide an update. I was able to contact my dealer's service dept this morning and said I could drop it off and they would make time for it and have it back by the end of the week. I just got back from dropping it off and while there had a chance to talk to them about it. So according to Polaris, the throttle cable problem is not the routing, but during assembly at the factory some of the cables were knocked around, stressed too much and kinked. They are simply going to inspect the cable for kinks and/or sheath damage and replace if needed. The Service Mgr didn't know about parts availability as the ones they've seen so far did not need replacement and were fine.
The throttle switch is just going to be inspected for proper fitment and make sure it has the right amount of free play of the pin and shims and the lever moves freely. Some were apparently too tight and some too loose. They said they would also check to make sure the switch is functioning fine after adjustment, if necessary. Some of the sleds they saw needed a different number of shims for proper free play but no switches were found to be defective.
I feel fortunate that my cable has no kinks to what I could see. Hopefully no issues are found that I can't see and can ride this weekend. I do find it odd that the dealers were instructed to leave the throttle cable routing as is if the sheath was find. You'd think they would want them to reroute it to a better, cleaner position.
