so your saying because the belt was so hot that it was a clutching issue, and this was the culprit because of the primary, i think if you run over to the doo fourm it has been proven over and over that lack of cooling is the culprit rather than any other
if your not smart enought to put no air vents in, remove foam, cut some plastic, then this will be your outcome, and this goes for your pros as well(common sense item)
ask any dealer
nothing wrong with your clutching but your clutches get smokeing hot? i mean iam no genius but smoking hot clutches is from lack of clutching or alignment. Putting a buttload of vents is just a bandaid, clutch till they run as cool as you can get them, then throw some vents on
How about just cleaning all the slimy oily goo off of the clutches? I'm still running my original belt on my XP.... no magic, just a Roosterbilt clutch kit and I keep things meticulously clean. And it is amazing how many belt burners I have "fixed" with some proper prep, cleaning and set up.
Butnow.....
and a new curve ball: for those of you that have ridden both..... what are your feelings on tracks? The 16" wide Doo (non ported now) vs. the Poo 15" wide track?
My thoughts are this. Both stock tracks work well on the Etech and the Pro. But the track I personally feel works the best in deep powder is the Powerclaw. I ended up switching mine out for the powerclaw. Only down fall is for the Pro, it's an additonal couple hundred cause you hav't too switch out the drivers as well. I don't regret spending the money though, it's a noticeable difference.
you polaris guys are too smart for me, first year sled that works somewhat and you know everthing allready, hope to see some of you on the hill, and put some vid up for you to exsplain why it never out performed the doo
Funny...FredW just gave me 12 bad reps!
Find a knife and walk into it.
1. You take these forums way to seriously and are in need of some help.
almost to 75 postswill we see another thread about keyboard highmarking with the same title for the unpaid members to stroke it out? or will the moderators who do very little but take advantage of whole sale items from vendors head them off with their stellar keyboarding experiance? only time will tell. maybe we can get some inteligent insight from snowmobiliers Grandma on the subject,,,, she does help many keyboarders with their keymarking skillz
