is the rocker bushing in the clutch??
Yes, weight/rocker bushing in the primary. periodically it would get thru 7400 to aabout 8200, but if travelling thru the field and hit it it would stall at 7400 and pull down to 7000.
Fullmonte
No haven't gotten it to run correct, and have pretty much had it. It has taken away allot of the fun of sledding. It is constantly a struggle to stay positive while riding when you sled runs like sh$t. It can take a nice sunny day and make it seem like rain. I’m taking a week off while I decide what to do with this sled. Never owned another brand before and never wanted to but I've got to bring the fun factor back into sport for myself.
Rode Saturday on the new flash and sled ran exactly the same as the stock program (mine is a 2010). Still have the mid range stumble at low elevations that goes away by 6000' but once up there the top end power drops. Guess I'll call the dealer tomorrow and give it one more try before buying the PCV.
You pretty much hit the nail on the head for me too. 2010, reflashed last week, and the only difference is i lost my top end. Worse now than before!!! Does dynotech jim have a program for the new flash dialed in yet??
The new flash didn't change top end, I'd look for something else. Carl's told me it was to help the map at lower R's where the EPA emission check points require it to be lean, 4000 and 6-6500 RPM.
I don't what else would of, nothing has changed on my sled, except 50 more miles on it now. Pulled 8150 all day long before the reflash. Now i pull 8000 on the flat and only about 7850 pulling a hill w/powder.
Your dealer might have disconnected the pipe sensor wire when doing the update. Or bad fuel, fouled plug, etc. Or your dealer may have installed the wrong map. There are other possibilities.
An unpluged pipe sensor should make the check engine light flash. I would change plugs first. these sleds seem to semi-foul plugs. where they still idel but maby a little low, and dont quite rip on top like they should. i have 600 miles on mine and have probally gone through 6-7 sets of plugs.
2009 or '10?? This sounds kinda like mine. Seems to run pretty good in powder (off and on throttle), but when trying to hold the throttle at about 7-7500 rpms' on the trail it cuts out something horrible. I just had the new reflash done on friday, and it is just as bad if not worse than before. If i knew a pvc5 would solve my problems i would pull the trigger, but i am beginning to wonder now. Also sled will only pull 8k now, before it used to hit 8150.![]()
Sorry bad news. I still have the problem. It is on a 2008 D8. Latest Flash has been done and still had the problem. They tested all senors, ecu, stator, changed fuel, plugged and unplugged the ethanol wires. They have tried all color fuel injector maps, went thru both cluthches, new plugs. Dealer has been riding it and says it is getting better, but still a problem. Belt is new. Ran it down and put good fuel in. They have swaped out exhaust valves with another sled to eliminate that. I ride flatland at 2000 feet and i swear it was working good at 4000 couple weeks ago. Might take it back to 4000 foot area this weekend and see if it works. When you start the machine up, warm it up, and then run it it will hit 8200. Back off and then hit it again and all it will get to is 7400 then detonates back down to 7000 with a detonation bog (seems like half the motor is running, falls right over). But no detonate lights come on. Standing on the jack stand it will consistently hit 8400 rpm, but not under load. Dealer has been excellent and if we find something will let you know. He is going to try 66 g weights (have 68s in now, which should be correct weight). When i got it i rode it with 62 gram weights and it was overreving on flatland (which it should), but i did not notice this bogging issue.even loaded up with oil in gas.
IS this what you are seeing at all? If PCV works let me know, seems we have a similar issue. Seen another thread where the guy mentioned similar issue to us. They took some readings off it today at idle, mid throttle and pinned and sent some "data" to Polaris. If anything comes back i will let you know. Sounds like Polaris has been working close with the dealer.
Dave, has the dealer checked the tps with a multi meter? or just with digital wrench?..it needs to be checked with a multi meter..its more acurate then digital wrench..also have seen a couple of sleds that were acting up fixed with either an egt sensor or a air temp sensor(sensors all tested good on digital wrench) theory was the sleds were injesting lots of snow around the headlite and contaminated the sensors...also what octane fuel? seems the sleds dont run as good if they have to much octane....(stock mine ran better on 87 octane then 90 octane)...
I will check on that tps issue with the dealer and ask him, thanks. If i tell him to check with multi meter what is he checking? Maybe he will know that. I am not overly mechanical. I kinda think he was using a multi-meter when i was at his shop, but will check.
You have jogged something. When i went to the 4000 foot riding area we got there late and i had to use 87 (regular in canada) and it worked. When i got home i put in 91 (premium) and then was having the problems. I thought it was the elevation that maybe made the difference. I hear so many people talk about good fuel that i never thought about it. What was yours doing with higher octane???????
