Dave, has the dealer checked the tps with a multi meter? or just with digital wrench?..it needs to be checked with a multi meter..its more acurate then digital wrench..also have seen a couple of sleds that were acting up fixed with either an egt sensor or a air temp sensor(sensors all tested good on digital wrench) theory was the sleds were injesting lots of snow around the headlite and contaminated the sensors...also what octane fuel? seems the sleds dont run as good if they have to much octane....(stock mine ran better on 87 octane then 90 octane)...
Had the new flash done and lost rpm on top with little change in mid range. I took it back to the dealer and had them put it back to oct flash. Sled runs better now but still can only get about 8000rpm above 4000 ft, put stock pipe with hps can on and could only get 7900rpm, put back the slp single and put the 1062 weights in,sled worked good but still only 8000rpm at elevation and only 8100 down low. The one big difference I noticed between the stock pipe and slp was the track speed, from 5 to 8 mph faster with the slp pipe.
AK I am putting in a additive that gives 3 to4 octane boost, I think I will leave it out and see if their is a change. I am thinking about putting back in my MTX weights, I kind of like the way the sled pulls in mid range with them.
All so thinking about ordering the PCV.
