Glad I’m not the only one. My 23’ boost started doing this today.I have a 23 boost 155 that has around 400 miles. It has ran great until the last few rides
It would run good for about half the day then it would pop out the exhaust and then fall on its face when boost would start to increase and eventually throw detonation code. If I rode easy without getting on the throttle it runs fine. Once I to try to give full throttle it acts up. So sometimes it will run for hours with out an issue and sometimes only about 45 min.
I have defiantly felt that on warmer days it is worse then when it’s cold. It also feels sluggish until I drop in altitude or could be due to cooler running since I’m going fast at low load. Ride between 7k at truck and 9k on top
Details
Has a Can and clutching.
Stage 2 tune for pump gas 91 none E
Have rode it with this pretty much from day one. With out issues until recently
I have the Ez Link and have data logged it a few times but nothing pops out.
I have checked reeds and intake boot all look new
I have checked all the sensor connections
The data logs show solid 59-63 fuel pressure
Tried 50/50 mix of 91 none E and 100ll
Have always ran 91 none E
Changed spark plugs 2 different times. The first time it happens I changed plugs on the way back to the truck it then ran great. Next ride after lunch acted up again. Changed plugs again no change.
Did relearn on exhaust Valves and waste gate
I added some fuel injector cleaner and thought that helped some
Have had the mag side spark plug loosen 2 times so I know it is actually hitting detonation. I have not been able to get a complete ride in with the stock tune to see if it ran different but it doesn’t seem to be a tune issue since it’s so intermittent.
Feels like a fuel issue like the secondary injectors are not firing.
Possible MAP/boost sensor
Intake air temp sensor
Anyone experienced anything like this?
I was wrong, part numbers are the same.Fuel pressure sensor wiring appeared to be good. Got a spare AC delco harness for the trailer just in case.
Started the sled up for the first time this season the other day. Have codes P1388 and 1391... MAG and PTO aux injector currents below normal/open circuit.
I assume my aux injector harness is bad? And I assume I am on my own beings the sleds out of warranty? I see 2024 part number is the same, 2025 is updated.
Have the wiring harness fix done ! My 23 boost had to have it changed under warranty after about 500 miles.I have a 23 boost 155 that has around 400 miles. It has ran great until the last few rides
Details
My NA and my Boost did cut out on a deep day and I believe it was the throttle safety switch icing up, in both cases.Data point:
Got the new wiring harness last month on my 23 boost after low fuel pressure warnings. So far no issues, until yesterday when I had the sled momentarily cut out twice, just a few minutes apart. No codes or warnings on the 7S immediately after.
It was a deep snow day, belt slippage on occasion and some freezing on the brake/throttle scene, worked through those separately.
Anyone else having ongoing issues with momentary cut outs post harness replacement?
The fine balance of warmers on low or high! Honestly gauntlets seem to be the way.My NA and my Boost did cut out on a deep day and I believe it was the throttle safety switch icing up, in both cases.
It's been a rare occurance. If I can keep it rubber side down I have less issues.The fine balance of warmers on low or high! Honestly gauntlets seem to be the way.
