"Go aluminum frame!!!
Sent from my DROID RAZR using Tapatalk 2
That would be a simple cheap add on down the road.With that said. I think I might look into mounting a solar panel to run a battery tender. This way I'd never have to remove the batteries and I'd keep them charged and never have to worry about them freezing.
For those with steel or who are contemplating steel, look into a chassis coating such as Chassis Saver or POR 15. This is what commercial truck chassis are sometimes coated in. If your trailer is already getting rusty, you can have it blasted and get it re coated in one of these coatings for probably under $1500.00
I wouldnt load the suspension. Go over the skid and over the skis. If the suspension compresses the straps might come lose.
Sent from my iPad using Tapatalk HD
For the last several years I have been the guy that LOADS the suspension and straps from the REAR only.
My Nytros have NEVER gone backwards, but ALWAYS try to go forward.
Never had a loaded one come loose though..
I guess the "Best" solution would be a super clamp??.
<iframe src="//www.youtube.com/embed/CX4RLTXPVjk?rel=0" allowfullscreen="" frameborder="0" height="480" width="640"></iframe>
Look at his super clamp holds your sled. By the skis and track, unsprung components. Not by loading the chassis.
Sent from my DROID RAZR HD using Tapatalk 2
I honestly didn't even look at the price.
$1,000.00 ??
That seems mighty high.
Either way, I plan on going with two strips of E-Track right now.
So I see the difference between the Vertical and the Horizontal, but I do NOT understand why you are suggesting the Vertical over the horizontal?
Is it just a matter of trying to get the straps to lay FLAT as they pass over the skis or through the Track/Skid??
And the problem this poses me is that I want to use the Superglides in the trailer.
I know I will have a Carbide resistant floor, but I REALLY likes the superglides in my current trailer and would use them again.
If I do that, there is NO way to install 4 sets of E-Tracks.
Vertical E-Track
Horizontal E-Track
