Could, but.Could you not lay the E track to the outside (walls). Run glides next to that and one E track down center? Staggering straps would be minimal.
-|||| - ||||- < like so?
Could, but.
My 2 Nytros skies touch the outside wall of my trailer now and its an 8.5' width.. And that is with them set to the NARROW position.
So if we did it that way, the skies would be ON the E-Tracks.
This might be a solution.
Run the E-Tracks right next to the SuperGlides?
As opposed to inbetween them?
Other than the ODD BALL move, this trailer will have two purposes in life.There are certain types of removable shelving that fit into the eTrax. I would look at that to decide how you want to run the eTrax on the walls, if any. The superglides in the trailer floor to mount the superclamps is a superb idea, I would love to have that in my trailer. I would however supplement it with some 1500# D-rings just in case you haul things other than sleds, 3000# if you intend on car hauling,.
Well this is absolutley fascinating.
I just went outside to take a picture of how my lighting was set up, and low and behold, all the 12VDC lighting, internal and external, has stopped working.
that'll be fun trying to figure out WTF is wrong with that now.
Christopher, have you considered "O" track for your tie downs? it's aluminum , so when a stray carbide or other object scratches it, it won't be a rusty eyesore in 5 years. It is also about half as wide as e-track so it would save some more room for your ski glides. A couple of my buddies have it in their trailers and it is pretty slick. I'm not sure how to post pic, so here is a link to show you what I mean. http://www.amazon.com/Erickson-59133-Aluminum-Mounting-Individual/dp/B005JCQEXG
Thinking about interior lighting now..
Don't know jack about it.Christopher, have you considered "O" track for your tie downs? it's aluminum
Christopher, this is what I have in my trailer. Also know as aircraft tie down system. It works great and extremely adjustable. I mounted some on the walls as well to hold gear bags and such in place.
Dano.
The voice of experience speaks!!Don't have the lights mounted down the center. I have one in the center that I need to move to the side. When they are mounted down the center you lose about 4 inches of interior height.
