To clutch for maximum acceleration in good traction conditions, you should be shifting at the engine's HP peak from 400 degrees CS temp (maybe 7600) at clutch engagement to maybe 1250 on the longest run (maybe 8300) (steel turns red at 1250). Knowing exactly where the HP peak occurs makes that possible.
We used to think that we were getting best acceleration shifting at torque peak (a few hundred revs lower than HP peak on a typical 20 second dyno run). But eventually, after 20 years of doing this dyno testing and converting that data to best possible field/ track performance we realized that we were really shifting at cool pipe HP peak.
Jim things are starting to clear up a little here. This is mostly a Western forum and perfromance in snow & climbing is likely the goal for most of us. A drag race clutch setup just doesn't work well for us....the clutch needs to backshift in different snow conditions. Actually most clutching setups are likely the result of trial and error in the field so clutching to torque or HP may be just theory to most of us.
The HP peak RPM is a constantly moving target, moving up and down as pipe gases heat up and cool down. That's why I thought it would be good to create a pipe CS temp/ peak HP RPM chart or map, to be useful for hotrodders to achieve best possible acceleration by measuring their own CS temp.
Now for revelation #2, today we dyno tuned our first Dragon 800 Switchback. This was a whole new ballgame--instead of 110 lb/hr peak HP fuel flow this one was in the mid-nineties lb/hr! With cool coolant to eliminate midrange knock we made exactly the same peak HP as the Dragon 800 SP with PCIII yanking a pile of fuel, 152-153 A/F in the 11's and mid .60s BSFC. According to Polaris-savvy people the Switchback has the same ECU programming as the RMK. If that's the case, then the question that must be answered is how does the Switchback/ RMK ECU calibrate at high altitude? For you mountain guys that information may be provided by Bill and Donavan at Xtreme. And for mountain guys, the fuel flow/ HP/ coolant temp graph I posted here is useless for you, and only needs to be an eye opener for the flatlanders who own D8 SPs.
In order to use the BMP pipe mod on the Switchback, we had to add fuel heavily in the midrange to keep it knock-free, and some on top end, whereas with the SP we were able to reduce fuel flow for max HP. Everyone needs a wideband.
