When I purchased my '05 900, I was told that there were three different injectors that may come on the sleds. I was told that not all injectors flowed the same amount of fuel so they sorted the injectors into three groups; red, blue and yellow. Each color corresponded to a different flow rate of the injectors. In order for this to work the injectors had to match the right fuel map on the ECU. For example, if you had "red" injectors, you had to have the "red" fuel map in the ECU.
Assuming this is correct, could this show up on the dyno as a different fuel map? It would be good to know what injectors the Dragon and the SB that Jim dynoed had, red yellow or blue. As I recall the injector color was listed on a box under the clutch guard on the newer sleds.
Jim, let us know what you find for injectors on any 800's that you have come through your dyno shop.
Thanks
SpeedWobble
There was some mention of this last year as well. The possibility of different injectors flowing differently. This goes back to some poor running issues some were experiencing. Keep those wheels turning everyone. Everyday, one step closer to perfect running sleds.
