D
dynotechjim
Ron you're right about maybe not suggesting using ethanol fuel with the non-ethanol wire setting to lean out top end. that's good for some top end HP but might be too-lean in cruising midrange. That's why the PCIII map we supply only affects 100% and 90% throttle positions, and the rest is left totally stock.
At the AmSnow DTr Adirondack Shootout last friday DynoPort and Bikeman both had 160 plus HP D8 trail mod entrants. DynoPort used Boondocker, BMP used PCIII both reduced fuel flow substantially below stock to make that power on my supplied ethanol pump gas.
