Does anyone know if they grease the bearings or any other part of the adapt clutch? Got my first ride today on the new clutch and it felt like the clutch was slipping bad for the first part of the ride. It would just instantly zing up to 82-8300 rpm with little to no pull and on a few occasions I believe I hit some sort of rev limiter as I would hammer it, revs would zing up fast and then it would fall on its face. This never happened before with the team. After riding for a while it seemed whatever was causing it finally wore off the sheaves as it started pulling better and rpm’s dropped to around 8150. Prior to install i scotch brited the sheaves as I have always done and washed the new belt with soap and water also as I have always done. On the hill looking at it I didn’t notice anything out of the ordinary other than the clutch was hot as hell, which is to be expected with belt slip. I ask about grease because once I got home I decided to clean the sheaves and belt again just to be safe and I noticed a bit of an oily looking substance flung on the belly pan and bottom of the belt guard in line with the moveable sheave and weight area. Anyone else experienced anything similar?
