I just got my sled back from the shop for totalt different reasons, but now I have seriuse belt noise, and revers won't engage instead kills the engine/squeak.. it's a automatic belt tensioner on these as well? Any ideas on what causing it?
Check if idler bearing is seized on primary clutch
They changed thermostat on the sled, do the remove clutch to do that?Check if idler bearing is seized on primary clutch
Yes, exactly. That steel part is a bearing.They changed thermostat on the sled, do the remove clutch to do that?
How do I check this, is it the steel part between the sheeves that the belt rests on (not good with terminology in English)
Check you primary clutch torque. Most over torque it causing it to do exactly what problems you are having. It needs to be torqued to 50ft lb and secondary to 60LBI just got my sled back from the shop for totalt different reasons, but now I have seriuse belt noise, and revers won't engage instead kills the engine/squeak.. it's a automatic belt tensioner on these as well? Any ideas on what causing it?
Retorqued to 68nm or 50ft/lb and it is now perfect ?Check you primary clutch torque. Most over torque it causing it to do exactly what problems you are having. It needs to be torqued to 50ft lb and secondary to 60LB
Well i got happy to soon, after one hour of riding center bearing is "stuck" to the shaft and spins with the sheves.. on my other sled i can move it with my fingersRetorqued to 68nm or 50ft/lb and it is now perfect ?
I had to replace the Bushings on the rollers also on my Adapt- However I used the bushings from Bikeman- it's the bushings used in their weights ( Snypr ) a lot better bushing should last longer than the fiber rolled one in these Adapt clutches,I've got a few hundred miles on my Adapt on my '19 with a Boondocker. One of the rollers lost the bushing after ~250 miles or so, swapped with a used spare & no issues since, though I have a new set on hand now. Performance wise, I haven't quite matched what I got out of the Team. If it stays together and doesn't crack, great, but only time will tell.
out of curiosity, do you have OEM pins in the rollers??? or aftermarket??Update, roller bushings were trashed by the end of last season. I put fresh ones in before first ride this year. 4 rides, maybe 150 miles and they fell apart. Swapped in new rollers again. Going to try aftermarket bushings next time around. In hindsight I would have just bought another Team clutch.
