I'm fairly unimpressed with my 850, talk about an over-rated and over-hyped snowmobile. Its no wonder they didn't have any demos available for us to try last spring, I would never have sold my T3's if I would have I ridden the 850 before hand. I've ridden the sled 2 days and I can draw some conclusions about issues they should have figured out before releasing them to the public, makes you wonder if their engineers/testers even ride snowmobiles.....
1- The porting on the front of the running boards does not evacuate snow, you loose the 1st foot of your running board to snow build up and it can't be easily modified because the steel protector for the chaincase and brake stick out way too far under the aluminum running boards. You can't use the part of the running board you often need the most because its full of snow.
2- There are no tow hooks, you can only push down with your feet and can't pull up, loosing half your leverage is a major step backward.
3- The front end rides light, it's squirly on trail and the sled doesn't get on plane in deep snow, the back end trenches down like a boat that can't get on top of the water.
4-The panelling is still very bulky, could easily have been slimmed up by 1-1.5 inches on either side.
5-Took my hood off this afternoon and noticed the EGT wasn't in the pipe...
6-Some of the wiring from the reverse switch has exposed copper where the plastic/rubber casing has cracked- my snowmobile has 45 km on it?!?
7- The tool kit characterizes Ski-Doo's arrogance perfectly. They will leave you to die out there.
8- Ski-Doo supports commercial guiding operations that have operated without approved tenures/sub-licenses for years in BC! (Not relevant to the 850 but worth mentioning)
The throttle response is better off the bottom but it doesn't feel like there is anymore power in the top end than of the T3. Its really disappointing that these sleds fall short considering all the hype Ski-Doo has generated for them. I'm in for 2 of them this year, what a waste of $35K! Goes to show, try before you buy! JMHO.
Sad to hear this. Hoping this sled will live up to the hype for some of us at least. If it doesn't I will sell it real quick.
