That was my initial thought as well. Mahle has been using this in diesel applications for several years. Hard to compare there results vs nik cylinders. Claim is higher wear resistance! Hardness of the coating: 800 - 1400 HV 0.1? Maybe it will take 1500 miles to smooth the cylinders down and you can re ring and be good vs 5000 miles as long as your crank bearing stay in one spot. In other words we as the consumer get to finish hone our cylinders with these rings.lol. In all honesty i am not sure why we have to go out on a limb with a new motor and experiment when we have tried and true stuff that works? Would the motor be that much less if we had more suitable crank bearing and standard rings? Would it still make 170 hp. New technology/process can be great and can be a curse. The 10 minute youtube video with the 2 yaahoos talking about all the new features of this motor would of been a lot shorter and so would this thread.
I'll take an educated guess and say that the Piston & rings in the 2013 thru 2017 800 small blocks are going to last much longer then the 2019 850 Piston & Rings.
This spring & summer i will be able to see the difference between the Factory cylinder finish verses our finish.
Mark my word...... if hard starting contiunes after they are broke in and the leak down % goes up we all know what happened.
Ohhhh.... and I commend the shop owner doing a video for polaris.
As for the content of the video its horrible. ( Polaris white collar finest. )
I have never had to do that to a Polaris EFI...... and guess i will never.
Taking the plugs out and pulling the rope is RETARDED !! If you forget the kill switch it could be a real bad deal if lets say an injector stuck open and the case was full.
I will say this........ don't do anything in the video.
( Remove the belt.... Have someone hold the throttle wide open and pull it ) the nano second you hear it fire let the throttle off.
If its flooded it will be to loaded up to over rev right away.
Dan
