2025 Rumors
The only upside I could see here is having functioning brakes without a QD belt in place.
Doo's design of having the brake rotor located in line with the jacks haft has created so many problems related to impacts, freezing, etc.
Hard to argue, having brakes at the top of a big hill when the QD belt lets go is very beneficial.
Why ports? Weight? Seems like the offset in durability isn’t worth the little savings. I know there was lots of talk about loss of floatation with ports when the Doo XPs had heavily ported track. Not sure I buy into that though.
The most important reason to port a track is to allow depressurization in the tunnel at the front where it pinches off. In that area snow and air are being compressed and drastically reduces track speed, especaily when there is little clearance between the track and the heat exchanger. Opening up ports in the track allow air and snow flow into the skid.
On my 25 I had the ECU die then the actuator that runs the exhaust valve die. They happened about the same time. Both replaced under warranty super quick by my dealer. The most annoying part was I had a pump gas tune from VOHK on my sled and when they replaced the ECU it was lost. The license is tied to the ECU. Called vohk thinking they would just allow another license. Nope. Told me I have to pay for a new tune. Needless to say I won’t be purchasing from them again.
A few things on my wish list…
- As far as advancements, I’d love to see a breakthrough in efficiency of the drive line. Lots of HP lost between the primary clutch and the track.
- We have seen the OEM’s deliver aftermarket goodies on stock sleds for years now, turbos, 7S, Pro-Taper bars, etc… how about a factory lightweight hood as a S/C option? Improved intake would also be in this category.
- I have my ‘22 boost setup pretty good, one of the things that would make me consider a ‘26 would be a version of SHOT.
- How about a simple way to adjust the limiter strap in the field? One of my early 2000’s trail sleds had an eye bolt type tension adjuster. Cheap, easy and lightweight.
If you mean a lightweight hood as in no headlight...
Extremely unlikely as a snowmobile still needs to be SSCC compliant. Without that it should be non-trail legal. If they start going outside SSCC then there is a chance of the government stepping in where as now the OEMs agree on changes to SSCC and meet compliance.
How did the the vohk pump gas tune compare to the 25’ flash?
An Oxbow light or similar should satisfy that requirement
