you cant say these things dont you understand that every 45 minutes they release a new game changing revolutionary piece of technology that includes but is not limited to more flickable chassis made of pure helium. its only arctic cat that is still on an updated 1975 panther chassis, and if you dont believe me just read a doo or poo forum they will tell you how heavy and underpowered the cast iron cat is.I know i know those are RMK’s
But i wanted to post these to show just how similar the pro-ride and axys really are 2011-2021. 10 years on a chassis. And I can’t find a “naked” picture of a matryx we can agree the matryx is the most different with new tunnel and running boards. But my point being for the throller.
They’ve all done the 10 year stretch of a chassis.
If you really look at it. Cat is the only one that did a rear suspension total change in that time.
Witch one of these pictures is the axys?
The Axys was like 95% different parts. And it is night and day better than the Pro, far from a reskin.I know i know those are RMK’s
And here we have the typical Polaris and doo Koolaid drinker.The Axys was like 95% different parts. And it is night and day better than the Pro, far from a reskin.
You are wrong, the one with the red is clearly the Pro. 95% new parts may be the “marketing way of speaking” but 95% is 95% fan boy.And here we have the typical Polaris and doo Koolaid drinker.
Not sure in want order they pictures are in. But the one with the red is the axys the other is a 2013 pro rmk.
The lightest of all the years at 408lbs.
95% new parts is a marketing way of speaking. Look at the picture it’s the same bulkhead same tunnel same same same.
Matryx has been the most different but it’s the same bull head and front frame and over structure just the tunnel and running boards are changed.
This just in. Snowmobiles continue to be snowmobile shaped.And here we have the typical Polaris and doo Koolaid drinker.
We looking at the same picture?If it matters, the red one has the scalloped hyfax which was not offered on the Pro series.
The red is definitely the Pro.If it matters, the red one has the scalloped hyfax which was not offered on the Pro series.
The one with the red is the PRO chassis, axys doesnt have the red brace by the rear suspension mount. Axys running boards also sit higher. The tunnel isnt as deep at the PRO chassis. Axys also has refined suspension and taller spindles. They may look similar but are very different in the way they ride.And here we have the typical Polaris and doo Koolaid drinker.
i still think they are on to something with the center rail skids. kmod and cat.
just waiting on polaris...
MORE INFO AND OPINION ON CAT'S CATALYST - Supertrax Online
Let's get in front of some of the more important details surrounding the Arctic Cat Catalyst platform. There's lots new. Some things are subtle and others arewww.supertraxmag.com
Belt Drive
Just for the record (because we respect the techo-knowledge of our readers and viewers), when we say belt drive we mean the final drive from the jack shaft to the drive axle. The CVT belt is in its traditional location. The move to belt drive is smart. The entire Catalyst project had lightness as one of its foundational tenets. Ditching the chaincase, cover, chain, tensioner and other assorted fasteners, not to mention the need to dump the chain oil when changing tracks, is quite simply, a huge win. Snowmobilers will remember Polaris has used a similar belt drive on specific RMK models.
Light Weight
The Catalyst has gone through a major dietary process and it extended to every piece of the sled. The belt drive is a big contributor to the claimed 10-percent weight loss. Anecdotally, we suspect the 10-percent number translates to almost 50 pounds. The new one-piece front bulkhead saves weight and lowers the overall parts count.
The new composite fiber running boards are lighter than aluminum and provide improved grip. The sled’s wiring harness has been rationalized to save one pound. The overall reality of weight loss is seen in the blanket reduction of actual bodywork and chassis dimensions. The sled is simply smaller overall. The Catalyst uses substantially fewer fasteners – which one-by-one, add up to weight savings.
Gas Tank
This feature intrigues the fertile minds here at Supertrax/SnowTrax world headquarters. The new fuel tank is shaped to reduce fuel sloshing. The idea here is that when you accelerate, a flat bottom fuel tank allows the fuel to surge to the rear and the opposite effect is true under braking. By designing the fuel tank to resist for and aft sloshing means the sled will be more stable under all riding conditions. Cool idea.
Centralized Mass
For sure, every engaged snowmobiler has heard of this fundamental chassis design principle. By moving the jackshaft, drive axle and crankshaft centerline closer to one another and, more importantly, slightly rearward, the gyroscopic effect of rotating mass from the three spinning shafts becomes more easily managed by the rider.
Also, positioning this group of parts closer together – which comprise a substantial amount of weight – the sled flies straighter, stays level and corners more predictably. The rider effectively becomes more a part of the sled. This design cue is in play in both Ski-Doo’s G-5 and the Polaris MATRYX.
ALPHA
The M-Series Catalyst uses Arctic Cat’s unique, proprietary ALPHA single beam skid. While the setup is lighter in actual build weight there’s another important detail at play. The ALPHA skid sheds snow more efficiently than any other vertical-specific snowmobile.
Arctic Cat makes a lot of hay about this as the more snow the skid carries, the heavier it becomes is in real-world riding conditions. Truth is, this is a legit weight carving feature.
That’s a round up on the Catalyst for now. There’s still more to talk about and we’ll be doing just that in the near future.
