2023 cat. Where is it?
Hopefully they catch up on their warranties soon too. They don't seem to give a chit about my destroyed 22
Man I hate this thing
Adding up parts to swap to a twin rail
I haven't heard much about a conquer 280 track? Similar lug pattern but different design, any thoughts?
IMG_20220305_183927484.jpg IMG_20220305_183703302.jpg IMG_20220307_215659884.jpg
Seeing that factory boost is becoming a thing, what do you think a Blast Limited would be like on pump gas boost? Might be a little much for new kiddos, but I feel like it would be a sweet wife/GF machine.
Maybe it would spin the track finally out of the hole when trying to get kids unstuck. Their clutching sucks. Would also love to hear the weight on one. Half the stuff is backordered. Buy a real sled if you want one for wife/gf. Does that mean you have to buy two?
That's really disappointing. We were all rooting for that adapt clutch to be the cure, but it isn't shaping up. I really hope manufactures figure out the kinks with these rolling bearing clutches because the performance is awesome. My buddy's boost primary (roller bearing) just blew up today sub 500 miles
Conquer tracks are light but stiff paddles so they take a couple hundred miles to break in and work decent in soft snow. Probably good for heavier or setup snow though.
Just cause I wanna learn, when the primary does that does it damage that shaft so bad the lower end has to come apart to replace it? Iam just thinking of a motorcycle engine where the shaft is worn (my only experience ) I did once break the snout off a crank shaft and had that same feeling. Sorry for the dumb questions
Like IDspud said, it all depends on the circumstances of the situation. If you have a hand full of throat and the primary explodes like that, chances are very likely the crank shaft will bend. And correct, the lower case has to be split to replace. It's probably more the norm then an exception the crank is damaged when a primary explodes. Along with a bunch of other stuff. It's a nasty situation.
Time will tell on the ADAPT. But with the Team clutch, if you are inspecting it regularly (basically after every ride), there is a good chance you can catch/see a crack before it goes boom. The most common thing I've seen is a crack starting at the bearing on the outer sheeve. It can be tricky seeing it, but if you run your finger nail on the lower part, closest to the roller bearing, you can typically feel the crack.
Indeed- it's a after/before every ride inspection and can sneak up on a person if they don't look close enough.
Clean your clutch faces prior to inspection......
I use a dentist style mirror and remove the belt for inspection and can catch the smallest of the fuse in the time bomb.?
I don't know how your wife rides, but I would have to guess the Blast might be low on power. If it is, and you still want something very similar, but with more power, then you can go for the Polaris 650 146. AWESOME sled for the lightweights that still want decent power.
This is isnt just a kids sled, Ive spent a fair bit of time on a 155 2.7 and also own a 600 Alpha. 90% of riders would be better off and learn better habits on a 6/650.
Saw the video, Josh; that really sucks! Definitely a defective component or improper assembly. I've got to question whether you really want to trust anything you buy in the last couple years. With all the supply chain issues, using whatever parts you can make work due to shortages, production interruptions, workers having to spend the whole day wearing a mask - there are just so many more things to contribute to a defective product, as if there weren't enough before. If and when I buy a new sled, I'm going over like it were a used sled from someone I know couldn't wrench but thought they could.
After reading about issues with the Adapt clutch and the P-22 on the Boost, I'm find with the P-85. The advantages are just too little to offset the issues we're seeing. There was even talk in the Matryx subforum of guys going back to the P-85. I like the idea of a roller bearing, but until they can make it last as long as the old-school stuff, I'll hold off. It'd be good to know what happened to Josh's sled; hopefully it's not a common happenstance. Even with their "old" chassis and engine, Cat can still sell sleds, but only if they can maintain or improve quality. Nothing kills loyalty like having a sled go down... Well, unless you're someone like Burandt; wonder how much work he has to do when the factory experimental sled he's riding blows up.
