My 05 summit squeeked after 500 miles-carb boot crack
Then my 08 xp top end went at 1700 miles-cause not yet determined
Good thing it gave up the ghost at the end of this season or I'd by crying like the rest of the x-pee owners who have issues with BRP.
First year glitches in order of occurance:
problem- solution-
belt exploded through side panel dealer may replace sp - good chance
2 belts(166) 20/49 gearing, 1/8th 2ndary shim, 377
right handwarmer element failure -put on fly bars with better heating elements
(update replacements get very hot as well)
rear torsion springs bottoming out(set max) - Put in delron inserts. These help
keep springs at correct position.
- stiffer springs hinder ability to
get on top of powder (transfer)
This works = no bottoming
Intake problems (aka deep powder bog) - Cone filters=fair, velcroed teflon
mesh or older rev intake foam over
existing screen=good, secondary 3"
tubing between headlights through
top of dash w slp=best setup
clutching off (high engagement @5k rpm, - 2mm over rollers(+5g) with
trouble holding rpms above 8000 in long climbs) skidoo hollow pins(15g)
and 413 to 415 ramp change
magnetic reset button delamination, - different glue-needs redesign
random trip meter computer reset when starting no solution-software glitch
rear grab bar failure (bends, shatters, breaks) old rev grab bar bolts up
BRP did a great job saving weight
with 4 new holes drilled
oil injection cable adjustment off reset to 28 mm as advised
(2-3 quarts of oil for 10.5 gal of gas) Considering premixing with
oil res and pump removed
throttle/injector cable setup inefficient(sticks) buy 2010 950 etec (170hp)
or use Arctic Cat 440 cable
deep snow hillclimbing track speed 37-42mph - Install Aero 66 and @15 psi
getting 75-80mph track spd
in steep and deep
