O
Original Tetonice
1st off nobody here said the center roller levers did not work.
The only thing that was mentioned is that "HOW the center rollers work", "the personality of them", "what you would observe when you operate them".....can be replicated with thunder shift/heavy hitter levers.
...ot said clutch kits don't work.
When I was in NY testing the 1200 turbo with Justin Fuller (http://fullpowerperformance.com/) I was given the task to tune a set of the center roller levers. These levers were one of the first sets for nouis to have in a skidoo sled, they still had blue layout dye on them and some of the ramps were not hardened enough, the metal was starting to smear. Some ramps had a blue dot, some had a red dot on them; different curves.
I was given the task to see what I could do to get them to work in one of the turbo 1200 sleds. I spent about 18 hours of testing with them as per Justin and CJ request.
I ended up going with the dalton brute levers for the particular application because they were the only levers that I could load the engine hard enough to come off the start line without breaking the track free.
The dalton levers helped us win the American Snowmobiler Manufacturer's Challenge for Quickest 60 foot time of the weekend, highest mph in the low octane turbo class, and the Quiet Giant award.
In the end I rather calibrate using as stock as possible. Make sure alignment is good and calibrate the clutch details so that rpms do not fluctuate under wide open throttle and/or if fluctuate under w.o.t. the rpms recover quickly, then you will have a good calibration.
Plus having Dalton at my side with Dale being able to make me anything I need regarding helix's at the snap of a finger and overnighted to a testing location, I can't beat that.
The CRA was Never Developed to work with the 1200 Turbo. Im surprised you didn't know that Joe. Had you called SuperTorquer and spoke to Randy the owner he wouold have told you that.
FYI 4 stroke turbo's require alot of weight in order to keep the rpm within powerband.
Nice try at changing the subject from the XP to 4 stroke turbo's.....Haha your not fooling anyone Joe.
Joe go to www.SuperTorquer.com and let me know if there is a CRA application for the Skidoo 1200 turbo or non-turbo LMAO
OT
