P
product tester
cc I rode your sled yesterday that thing rips rode an m8 at 15#s the day before and I would say they are pretty close the m 1000 at 5#s is alot of sled .
WASN'T ME! Why is my name posted above?
I'm leaning towards a BD pump gas Dragon with small intercooler. 12lb's 100ll and no need to mess with different injectors with the dragon......thats a plus in my books! The Dragon has No lag...None! Instant throttle response.Yes it was you told me to say that.....Just kidding so what the deal for next year,,how big you gonna go after riding the beastly you had? Terry
Have seen a Cutler M8 kit run 14+ lbs with stock injectors. So, what do you mean exactly??
What fuel pressure and fuel? Duty Cycle?
At sealevel the DC is about 99% @8psi on pump fuel.
What about putting m1000 injectors on the m8 setup?
I thought the m8 stock injectors were only good to 9lbs or so? Actually I'm pretty sure they do.
they run 10 consistantly and there are guys running them higher but I dont recomend it .
10 #s with single injectors
wont make the power that dual injectors make at the same boost.
I have set up lots of sleds with single injectors and they run good, but when you put them aginst one with dual injectors they wont make the power.
How do you make more power by throwing more fuel at an engine running optimal a/f ratios?
What is optimal?? Is this the A/F that makes the most power or the A/F that you were told to run at?? I know Shain has told me that the 1000's like to run a little richer, and make the best power when running in the high 11's to low 12's. Shain, correct me if I am wrong.
Also, better fuel atomization has only been an important factor in engines running better, so maybe the dual injector does a better job.
Not really sure, just throwing out some ideas.
