sorry for being so dense, but can a picture be posted of the correct connector?
Hope that helps, again location is PTO side above the upper shock mount can't miss it
How important is the wot voltage since even adjusted i still se 4.34volt wot even do the settings base and idle are spot on.
after adjusting the sled allways starts warm,cold on first pull and idles fine, no hesitation thrue rpms. but i dont seem to get past 8100rpm
I think you shall not let it slam shut. What happens then is that the trottle blades gets "forced" into the trottle pipes. Different force, different result from time to time. Close the blades carefully and adjust the base setting.
So anyone solved the last 10℅ for sure?
Sucks that going 8350 and hitting the last 10℅ hearing the sled change tone and lopse 200rpms, the powerband is really noticeable and thats frome one coming off a turbosled !
As mentioned above I added a spacer to the throttle body stop, which limits its travel. I felt this helped a lot. Now between 90% and 100% throttle I can hear _almost_ no difference in exhaust note and observe _almost_ no change in RPM.
It's nice being able to simply squeeze the lever rather than trying to feather it around 90%.
Still not seeing the RPM I want. But it's more rideable now.
