Snow Eliminators vs. Better boards
I have to agree with bamfm7. I have sno-eliminators on my 07 M8 and spend a lot of time kicking out snow and ice. I'll be going with the plastic next time as well.
The powder coated BETTER BOARDS are the way to go, the snow does not stick to them at all. Does not matter if your on the trail or off, the BETTER BOARDS are worth every penny, the best dollar I have spent on after market parts on my sled.
check out feethookers. they are the BEST performing board and the BEST value for your dollar! available in red, balck or white with mounting hardware included for $150 shipped to your door (in the lower 48)
installed:
custom colors:
meahookers has some cool new coating options as posted in the last picture there, but the tried in true BETTER BOARDS are the only way to go in my opinion. guaranteed the best thing out there right now, i wouldnt even consider owning a sled with out better boards on it before i ever rode it. hands down the best mod a guy can do to his sled
I went threw this same debate over this summer. I settled on better boards, ordered them last week. I'll post photos when I get them and install.
installed:
custom colors:
PM sent.
Better Boards all the way. Went on first ride with them on today and loved them + you cant beat the f bomb far as service and answering questions goes.
I have "Better Boards" and would not buy them again. Bent cleats, cracks in the cross bars and peeling/chipped powdercoating.
Running board porting
I know you aren't near colorado, but to the others in and around colorado. Get qreiff on snowest to port them, he's in the denver metro area.
boards
longtrack 156 those boards look great.....what did you cut them with? I would like to make some like yours, I have snoweliminators but most of the rungs are broken out and I had to cover them in 1/16' plastic sheet to keep the ice from building up on them
boards
another thing to think about when adding boards is that the serrated grips that are between the holes , boot grips, are about 1/2" or so higher than the stock board floor so when standing you will be higher in relation to the bars, I had to raise my bars after adding the eliminators or my back would be slightly bent when standing, more than I could tolerate.
Has anyone seen either of these on a Yamaha apex ltx gt I need the one that will double as a tunnel/board stiffiner ???/ Which one runs up the side far enough to help support the boards?
This was a selling point for me so I went TUFF boards. They are over 3mm thick so I hope they'll make good strong boards.
Originally wanted F-bombs for his no-snow-stick coating, but didn't find any of his that attached to the tunnel side as well, so TUFF boards for me it is.
RS
I made them out of 3/8" UHMW. Attached them with 6/32 flathead screws with nylock nuts for traction, works well.
The boards were cut out with a router using a plywood template.
The original aluminum had holes cut undersize, then when the UHMW was bolted in place the router was used to clean up the aluminum, very clean.
I also had to raise my handlebars a bit more because of the added thickness.
just finished up installing the better board set. Quick and easy install, used a plamsa cutter to cut them out ruffly then grinded it back some allowed me to get them pretty much flush. Luckily I was able to borrow a pneumatic rivet gun or I would have been hating life.
Here are some pics of the boards
I tried to leave as much metal as possible (probably didn't need to) but it makes it look a little sloppy from some angles. I'm going to go back in with a file at a later date and clean em up.
The only thing I found was odd is I couldn't get the "nut" notch, to line up if I wanted to tunnel marks to line up as well..
