B
barry1me
I also need the instructions....can someone send me a set? bclaypool1@gmail.com
No they are the same . I finished an install on a 2011 last night and trust me, If its together right it all fits fine. Just pay special attention to anything that could rub and protect it.
wel i better get to the hardware store then. to make it work im going to need six 45 degree elbows for the big coolent lines. if i push them far enough down they hit the jackshaft othewise they are resting on the charge side of the turbo. its gonig to look pretty bad with all the hose clamps though
joshkoltes, what you are describing is pretty much exactly how mine fits. The 90* rubber intake tube isn't quit right. You can move things around a bit to get it to fit a little better, but the angles aren't perfect. I'm calling it good enough, but not perfect by any means.
As for the coolant lines, that's exactly the way mine are too. I just put a whole bunch of convolated wire loom on it, zip tie it up off the jackshaft & I am just letting mine rest against the compressor housing, hopefully the wire loom will keep it from rubbing through. I'm definately gonna monitor it closely though.
Gmustang would you make a list of all the the little extra parts that you needed to install the kit? Stuff you bought that was either necessary or helpful to the install. I have read through the thread but It would help if it was all in one spot. Also, people could add to your list things that they used. Thanks in advance. Was there any tools that you also bought or are special that are needed for the install.
