redline
ill finish it up tomarrow
http://www.snowestonline.com/forum/showthread.php?p=2988279#post2988279
So if they are out of adjustment do we have to then adjust the tps to get .947 again or as long as the baseline is good just adjust the blades?I would add to this thread, everyone should check the adjustment of the throttle blades....they should be open from .0025-.003" with a feeler guage checked between the blade and the bore, this will give a nice idle of aprox 1700ish with turbo installed. From what I have measured myself some butterflies are factory set way over this range, .007+ this while not a issue with stock induction will give idle of 2000+ with the turbo install.
Just a fyi.![]()
