All I was saying is that if the 872 had the extra $800 worth of goodies...billet head, bored carbs, reeds, ypipe....your race would probably end with different results. Sorry for raining on the shr parade
There's an endless amount of variables that could have changed the results of the "race" to go either way.
The main point of this thread was to get a group of guys together that have BB sleds and to go have some fun! The winner was to be decided at the end of the day after ripping up the trees in waste deal powder! Unfortunately a few members have muddied it up with their opinions of how a race should be put together.
Too much reading for me. Give me the short version. So the SHR 880 was the clear winner?
Defiantly the clear whiner. LoL
DPG
Sounds like Snow Days in Thayne they do similar except rather than pass the Kitty guys are making side bets as to who the winner of each race will be. I agree lots of fun
DPG
Heres the new "Snowest BB Challenge" I propose:
"Get a "Kitty" going... every rider here who wants to participate throws in an agreed amount (say$200) to an agreed upon member to be in charge of said "Kitty" and I bet you get a $3k purse quick and payout goes to top 3.
So whose in?
"I'm your Huckleberry"
https://www.youtube.com/watch?v=lvlwVeNpFAk Heres a simple clip racing a turbo pro at 9K. I clearly wave him ahead at the start and he took a line he just climbed several times, I went straight up and realed him in pretty frickin quick.. Priceless is when he gets to the top and i,m already there, He looks down at his motor!. Yes he took a different line , its same results every time, A fantastic running 880 with a 3 inch flat rocks on the hill.I have many clips with same results , running a 880 Full mod however i,m running a 156x3 and he was heavier by a solid 40 lbs with stock 163 track.
Good to hear about your sled Slim. Just to make clear, I wasn't trying to imply you were having issues w/ the big bore. I've had friends w/ Pro's have electrical issues w/ their turbos, never once ended up being from the sleds modifications. Anyway, thanks for clearing up the "race" you had w/ the a 872.
If anyone is interested, their should be quite a few sleds of various states of tune in Lincoln, MT on April 5th. Check out the sno-b-que in the MT section. It always allows for some good competition. Big enough hills to allow the four strokes to show who is definitely the power king and allow the big bores to show the turbo two strokes, if it is not set up properly, they've wasted a lot of money. Depending on snow depth, the 3" tracks can really shine also. Makes for a good time seeing what works.
Well swrev How did things pan out did you go?![]()
The point was/is there is MORE than 1 guy who builds a good motor...
SHR860/880ETECS are always built to the highest standards and with the Wossner forged pistons I have the best dual ring piston on the market (even better than stock)...period.
RKT is the only other shop using these (custom spec) BB pistons
Short of a .020" bore diff (bigger or smaller) we carry water for no one...
SHR works with/for many dealers on installing complete clutching/gearing/chassis/track packages (the TEAM clutch is not required) since I actually ride/tune where YOU ride...
Summer pricing in effect so please call...BJ
The SHR860/880 T3s will be completely killer!!!
Since you claim to have the best dual ring piston on the market ( better than stock ) do you have any of your motors with over 5000 miles on them using the same piston and ring ?
DPG
As far as 880 pistons and I,ve run every one made, SHR,s are superior. The taper is better, oil holes and design is flawless. I assure you they are better in my motor than a stock piston, Hell the stock pistons had ZERO compression!Since you claim to have the best dual ring piston on the market ( better than stock ) do you have any of your motors with over 5000 miles on them using the same piston and ring ?
DPG
