snowmobiler
dyno
You forgot the "RPM" on the bottom and "HP" up the left side....dyno
Honestly all this talk about the polaris 800 being under powered is rubish. I rode every brand of machine and different track lengths etc, I found them all pretty close to the same, minus set up differences like clutching, gearing , track choice. The skidoo defiantly is more responsive but the arctic cat being 10 hp more I cant tell. With anything clutch work is what makes them go, its everything.
Polaris is and has been compliant on their motors(this came up in a thread a yr. or two back), if I remember right, the others actually used pts. to meet compliance and Polaris did it by compliance(no pts to use)..Just a quick question on this thread given the level of expertise. Do we think this motor design will be obsolete soon? Polaris hasn't made EPA compliant emissions changes to the 800 2 stroke. The government regulations are so bizarre though that I can't even tell if this is truly an issue. Seems like there is some cap and trade thing going on where the manufacture's aggregate emissions are what matters rather than the performance of a single motor.
wider power brand is what i was thinking too usually no matter what you do, unless its too much fueling and/or very low compression, if you dont have good top end power you get a wider and smoother power band, im thinking this is where polaris "detuned" their 800Possibly they are more focused on usable/midrange power to make sled highest hp....
if your cylinder is running cooler and has a more even heat across the piston and cylinder you can pull more, reliable horsepower out of it...shorter rods also make for more hp, does that mean everyone should shorten their rods for most hp?...how do you think that would work out?Forgive me, I stumbled into the Polaris room by mistake. This thread is quite entertaining!!! I would like to address the offset combustion chamber design Roffrider bragged up numerous times in this thread. I'm sorry sir, but someone has you terribly ill informed on this design. The way to get the most complete burn in the combustion cylce, therefore producing the most power, is with a symetrical dome shaped chamber, and center located spark plug. This allows for the best and most even flame propogation during the combustion cycle. Chrysler figured this out over 50 years ago (HEMI). Now, yes I know as I say this, Doo put the injectors where the sparkplug should be, and moved the spark plug to the intake side of the dome which I really don't think was a great idea, but I guess no cylinder wash that way. My $0.02 on that idea.
Now go ahead and flame on the Doo guy![]()
Yeah, I gotta comment on this(not Roff's offset chamber deal) but the Hemi head deal being the best..well yeah , sort of..Top fuel went to the Chrysler Hemi in the early days for 3 basic reasons, 1 they were inexpensive and readily available, 2 they were extremely strong in the block/crank, and 3, the hemi head in an unlimited top fuel motor allows better/easier control of DETO.. so yes, today it is the motor for top fuel.But its not always the best head design and in many many cases a wedge head is better. wedge chambers will normally make more power(everything else being equal, especially normally aspirated), engine design is much easier and cheaper, engine size is much more compact and most important both fuel economy and emissions are better..Forgive me, I stumbled into the Polaris room by mistake. This thread is quite entertaining!!! I would like to address the offset combustion chamber design Roffrider bragged up numerous times in this thread. I'm sorry sir, but someone has you terribly ill informed on this design. The way to get the most complete burn in the combustion cylce, therefore producing the most power, is with a symetrical dome shaped chamber, and center located spark plug. This allows for the best and most even flame propogation during the combustion cycle. Chrysler figured this out over 50 years ago (HEMI). Now, yes I know as I say this, Doo put the injectors where the sparkplug should be, and moved the spark plug to the intake side of the dome which I really don't think was a great idea, but I guess no cylinder wash that way. My $0.02 on that idea.
So yeah, in a top fuel engine I would run a hemi head setup, in most other apps..most likely to be a wedge head for all the reasons above.. On 2 stroke sleds, yeah hemi is a natural and most every manufacturer over the years has employed a variation of it..
