Are people actually seeing smoke when these go bad? On thing to keep in mind is the ecu will only "take" as much current as it wants. You can't trick it to take more.. so it doesn't sound like a current issue into the ecu per say...
anyone have an oscilloscope and a good and bad voltage regulator? And how about a three phase function generator?
Dang I miss the school days.
So anyways, the battery idea is best, though someone said something that the ecu is not at 12 volts but is at 5 vdc? I guess sometimes ecu's use a different voltage for the sensors, but normally the ground and the voltage wire go to the ecu as the ecu controls the voltage, not an external voltage source that the ecu uses.
Interesting problem, kind of reminds me of the issue on the arctic cats where people were removing 100 watts of lights from the hood and blowing their vr as well.
For those that are going to try something with resistors, get some power rating on them. Don't use those dinky 1/4 watt resistors. They tend to act like a toaster after a while of high current usage...
The grounds issue is an interesting one.. I wouldn't think a bad ground issue could effect the ecu and its sensors, mostly because the sensors are generally isolated in their plastic housings and do not have metal to metal contact. Though, deepdiver is right, grounds do some tricky things and floating grounds are really interesting.
What is really weird is the rectifier / regulator going out, and then the sled goes into a lean condition and burns the sled down. I think they got their fail safe operation a little messed up. lol
To sum all this up.
1) Do we know why the regulator / rectifier is failing?
2) Do we know what the output looks like after it has failed? (Need a good one to compare it too.)
3) Do we know what is actually inside the thing?
4) What are the specifications of the sled? Normally there is a listing for the electrical power supply.
5)Do we know why the ecu goes lean? Why the regulator / rectifier is failing in that way?
The nerd in me says some more of these questions needs to be answered before a solution is easily found.
As to the capacitor idea, I am not sure that would work as it really isn't a sink as much as a battery is.
For one of these that has failed, anyone take out the stator and magnet and take a look at it? It might not be a regulator issue at all, but maybe the source is not that good?
dang, sorry for the rant..
