L
lognomore
cooling for the VR
Just got my 07 dragon back together last week and rode on Sunday, ran great!! After replacing the VR, ECU, and stator. I did install a fan in the cover over the VR. The fan is a Panaflo high speed 92mm 12 volt. A resister of 5 ohms, 2 watts was installed in line so that the voltage to the fan would stay at 12 volts versus the 14 volts coming the power plug up front. Use the power plug that has the red/white and brown wires going to it. If you install a fan be sure to use at least 1/4 inch spacers between the fan and cover so that the fan will not hit the cover and cut out the louvers further forward so that the fan will be directly over the VR. Hopefully the fan will take the punishment, we'll see. If you can come up with a plug that will plug into the power plug it will make it that much easier to hook up, I couldn't find one.
