So can you piggyback a regulator to the regulator? Or can another type be used?
The stock one has 3 yellow inputs, 2 brown gnds., 2 red, and 3 orange wires that run to the ECU.
'09 800 Dragon with 2010 update and electric start/big battery.
Lost the voltage regulator and ECM melted yesterday. Battery doesn't help.
Since this is a Regulator AND a Rectifier.... I wonder exactly what is "going" on the Reg/rectifier??
I've also heard that it is a connector problem as well??? (memory is not as good as it used to be)
Well, my VR went out today and the ECU started smoking really bad but it still works. All the lights burned out and I'm not sure what else until I dig little deeper. What did happen was that I had slowed down to go around some trees and the engine started to run bad like it was running out of fuel but then it cleaned up, was ok I thought, but that is when I notice a burning smell and shut it right off. Opened the hood and could see smoke coming from around the ECU. The engine will start but the ECU starts smoking, so we just towed it back in. Even though the ECU still works I wonder what damage has been done to it and how long it will last. I will replace it along with the VR together. I'm really hoping that someone will come up with an answer as to why this happening. Like everyone else I worry that this will happen down in some deep hole somtime.
I lost my vr yesterday and it took out the ecu, hopfully with all the guru's around here we can figure out a way to protect the ecu when the regulator goes. My sled is about 5 weeks out of warranty, we will see if polaris still warranties it, it's a 09 d8. My dealer seems pretty confident that polaris will still warranty my sled and my fingers are crossed.
ECU = Electronic Control Unit
Seize
The seizure is most likely related to the issues that are being dealt with in the updates
and not the topic of this thread
