Here's a video of my problems, filmed it today. These are the things that happened during a 20min run. Last one is not dET but bogging.
Setting on the fuel controller is:
Green: 5
Yellow: 2.5
Red: 4
Green blue: 4
Yellow blue: 4
Red Blue: 5
http://www.youtube.com/watch?v=h660l5tqHcY&list=UUAs9eKxu9jDIsGEHl-sBvtw&index=1&feature=plcp
sounds like a bad wiring job with the afr guage problem.i switched to an amg guage. my sled was doing the same thing yours is (det). i rode it today and no det anymore (thank god). this is what i did to fix it. i took it in the shop and layed the heat to it, drying everything out really good. once it was dry i siliconed the back of the control box so no water can get in there. i also now have 3 zip ties on each side of my air box holding it together cause those 2 long bolts keep braking. i might go to a spring system soon if i get motivated enough to fix it properly. i re-gaped my spark plugs to .23. i grinded the air box tab where it was hitting and i bent the pipe guard where it was hitting. i was running straight av gas now im 70% 94pump and 30% AV, I switched to articat 048 belts, i turned my helix to the other setting.i cleaned the bov and put some vasiline on the o-ring for lube. i was on 6 pounds today at 5000 feet with my box numbers at
green 4
orange 4
red 5
green blue 3.5
orange blue 1.5
red blue 4
in the trees thats what i found worked the best. i raised the green and orange blue up on the trail out.
my pis in each cylinder is 90.
hope some of this helps.
some serious fuel your throwing at it, maybe bigger injectors needed??
green 4
orange 4
red 5
green blue 3.5
orange blue 1.5
red blue 4
Mine did that too, Justin said the stock map does it as well and not to worry too much just vary the throttle.
So what do i need to adjust to get my high cruise a/f ratio down?
Still havent got any answer from justin after emailing him two times the last 3-4weeks, it would be great to get an input from him also on this.
I found that u just can't cruise at the same rpm for long, unless it is wot or below 1/4 throttle. Pretty much have to vary the rpm's to keep it from running to hot.
This is a fact with any 2 stroke I have been on. They do not like trails at a cruse speed you must wick the throttle. I have been able to throw fuel so you can but then they will not run on the hill.
You dont know wtf your talking about. go back to your Doo section and blow smoke up every ones azz about how great your etech is!
