My case is not the same as stock, it is ported to not only fit the larger cylinders, but to allow for the skirts to stay as close to stock thickness as possible.
For example if you have a 10mm block, and bore a 4mm hole into it you have 6mm's of meat left.
If you start with a 14mm block, and bore a 6mm hole into it you have 8mm's of meat left.
With new cast cylinders you can have thicker walls in the cylinder, also allowing you to have a thicker skirt after making room in the case.
When Boring out stock cylinders, you are making things thinner than stock no matter how you look at it.
Im not saying your kits don't work, but from what I have seen with boring stock 800 cylinders, you can run into brakage in the exaust ports because of the lack of material there after boring.
Its not my choice when it comes to my motor.
Im sure you have a good kit its just not for me, and what I ask out of a motor.
Your kit has a good Rep. Im sure you will continue to do so. Maybe one day I will have the pleasure of running into a RK Tec motor, so I can see for myself.
Thank you for your input..
