I had very similar wear marks - but maybe not as bad - after doing the top end on my '12 Pro. I've got a long rod conversion, so it uses a spacer with standard height pistons. It came with OE pistons (to the best of my knowledge; I'm not sure how to confirm the markings), and something caused a locating pin to fail or a ring to break and eat a cylinder. I'm not sure if I ran them too long, or if it was caused by some fuel pressure issues I discovered after the fact (never any det warnings). Anyway, I had the cylinders welded and re-plated and put in Wossner pistons that I ran for a season, then out of an abundance of caution I took it down again to have the crankshaft gone through, and that's when I found the marks. It looks like the same thing, although my pistons looked cleaner when I took them out. I wish I'd run AXYS pistons (I chose Wossners partly after not being able to find '15 OE pistons - since discontinued) when I did the top end. OE pistons seemed like too much money with iffy cylinders, so replaced the Wossners with SPI Hyperdrive pistons. I also hand-honed the damaged areas with some fine grit sandpaper, and have the oil pump cranked plus 100:1 pre-mix. 3-400 miles since then and so far, so good.
My best theory as to what's causing it is ring flutter. Wossners, and it looks like Wiseco as well, uses a different style of locating pin than OE (which most cast replacements copy). I posted about this when it happened, and I heard some mention of similar wear with forged pistons. Meanwhile, others swear by the MTNTK fix kit, which uses a custom Wiseco piston. As best I can tell, both RK TEK and Bikeman use Wossner. Going back to when I blew a piston, the good cylinder looked almost perfect; if I had a time machine, I could have done the top end with OE pistons and avoided the headache. I'm hoping there's a good explanation here - is it specific to Wossner pistons, or has it happened with Wisecos too? I can't think of a thing I did that might have caused it, but I'm just an amateur when it comes to rebuilding these. To answer the obvious question, I did set the ring gap to spec. If this has ever happened with cast pistons, nobody here has ever mentioned it. Personally, I'm once bit, twice shy. I'm not touching forged pistons again until I know for sure what's going on here. I won't speculate on Wisecos, but this would be another bad report on Wossner pistons - maybe they just screwed up on a run of piston rings, but who's to say? I do think there's merit to running a taller piston, or ideally, a long rod with OE pistons (but that's more work and expense).
Well, forgive the long post here, but to the OP, my recommendation would be to buy SPI's fix kit, or find the one that uses Cat pistons if it's still available, and then run good oil through it and plenty (maybe turn up the oil pump even more, and keep running 100:1 pre-mix). If it works well for you, buy a leak-down gauge and monitor it. I'm sticking with cast pistons until I learn more, but even with "fix kit" pistons or long rods, you should expect to replace them periodically.
