had the new flash put in this am took it for a short ride. 100 percent better! crisp response, bobble gone, tachs 8350 rpm will give it a better run tomorrow but as of now I'm much happier today.
The sad thing about all this is that the warrenties are about to expire and we still have motors that cant hold together. Thursday when I was out the crank broke off bihind the primary. Dealer said its about a $3500 to rebuild. Thank god its still under warrenty. But this is the 3rd rebuild in 2000 miles. Cant even sell the thing because of this issue. Cant trust it to get to far away from the trail. Thats not what i bought it for. I bought it to ride and ride hard!! Sorry about the whining just frustrated.
I wouldn't call it whining when you can't ride. We feel your pain. I'm still waiting on an ECU from Polaris to ride mine. It's been down now for 6 weeks. I'll never trust mine after all the crap that's gone bad, and I have a 2 week trip starting on the 4th of Feb. I'm actually getting real used to riding my 600.which is supposed to be for family and friends to tag along.
PCV owners - Don't get the update and then run your PCV map. Your PCV map is an alteration to the map that is currently on your sled. Your are likely to be very lean up top if Polaris leaned out for more HP.
Here we go again!
But guys who are using PCIIIs or Vs or Boondockers and are happy with the way their D8 sleds run should wait on the reflash if they can because we're starting over again. .
OK, seriously a hats off to Polaris for continually trying to make these right.
However, I believe this is map 6 now. Ever heard the story of the boy that cried wolf? This isn't a system Polaris is going to be able to fix. I"m sorry, not trying to sound negative, but what they are trying to do was never meant to be done. This CFI 4 system just isn't going to be an EPA friendly system.
You take a 800 motor. It will always be an 800 motor, not a 700 not a 600, it's an 800. Then you take the exhaust valves and hold them closed to the size of a 700. Do this until you are within 1000RPM of peak RPM. Any question marks coming up yetLol This chokes the heck out of that motor so you can lean it as far as you can go for EPA testing.
Basically what I am saying is that the rpm is increasing which causes the fuel requirements to increase, but they can't because the exhaust flow isn't being allowed to increase with it. So instead the motor starts to choke thinking it needs less fuel.
You can't change the fuel requirements of an 800 motor no matter how hard you try. Look at 2 stroke dirt bikes and older model sleds. The exhaust valves open almost immediately. They are only there to increase initial low end throttle response that is all they were ever designed to do.
Or, try thinking of it this way. Would you rather have power that comes on like a stair case or a gradual incline. The staircase reference is a flat line that then shoots straight up. Which is what is happening when the exhaust valve is only allowed to function as open or closed. The older VES system allowed for more linear power to be made as the port opening would increase as rpm increased. Even the pipe configuration was not meant for a small exhaust port opening.
I'm sorry to be off topic here. I'm just trying to explain my opinion why they won't be able to properly map the CFI 4 systems on the 800's.
Sorry, I don't explain things well.Monte,
are you thinking that even the pcv won't get these to run to correctly since we don't have to go through epa with those? Just curious what you mean?
Sorry, I don't explain things well.I believe the PC V is the answer. The fuel controller will be able to adjust around almost anything. I was also hinting that I feel they are holding the exhaust valves closed too long. Either way the PC V can remedy the problems with the stock mapping. My point was that Polaris just won't be able to make a EPA friendly map with this system that is also reliable and hesitation free.
could the exhaust valves be drilled/machined to use cylinder pressure instead of the solenoids, or put the older style exhaust valves in? Or are the new cylinders not compatible with something like that? just putting it out there, could be way off base
tec, the valves are the same as the old ones in function, they are just vented thru the solenoid to allow the computer to control their opening and closing points....plugging the hoses makes them work like older valves....
