My sled is running great with the pc. I will be waiting to find out what exact changes have been made. I doubt it if they will have got he fuel perfect for best performance. Probably just enough to stop the midrange lean stumble and piston issues.
Most likely true, but that is enough for me. As if it does help/fix and not optimize, it will save me form buying a PCV for each sled and an Autotune to share=$600.00 ish.
PCV owners - Don't get the update and then run your PCV map. Your PCV map is an alteration to the map that is currently on your sled. Your are likely to be very lean up top if Polaris leaned out for more HP.
Looking at Polaris history, a OEM map that runs well and produces 154hp is wishful thinking.
just remapped 3 sleds tested them out in the tree rows. Idled much better and ran much smoother and cleaner. Worked awesome!!!
http://www.polaris.diagsys.com/modu...s&d_op=NewDownloadsDate&selectdate=1263228206
Does anyone know if this is the new flash for the updated fuel mapping?
what weight & how many grams you running to see those r's??
