pawpaw
you running stock spings ?
thanks
thanks
Now see if you can figure out how to get it to run at 7950-8050. At 8150 you lost snort with that setup.
In testing the sleds turned out to be significantly faster at 7950 even though the seat of the pants dyno felt like it was stuck in 3rd gear. This was all prior to Brad putting the 800 PRO with the power addiction head on a dyno so at that point it was only field testing and some educated theory. Now they have the dyno report and it supports what we've experienced on the stock motor/exhaust/timing with this head. The power drops off pretty significantly right at 8100.
A lot of clutch kits are allowing the PRO to even RPM higher under limited load (like a groomed trail) and then fade back to a holding R in heavy snow. That was even slower yet when we set them up in that fashion. That is typical of the stock high alt ap for Polaris. Most stock sleds will see 8200 and sometimes more with no load but in deep or heavier snow then they settle down into 8100ish. If you test sheave temps you'll see that is a hotter running clutch package then a sled that can pull to and then hold steady 7950-8050.
It would be interesting to see if you can even throw a bit more tip to your system and knock that finish R down 100 but still get the same pull and have it hold. If so you are there. The real telling part with these clutch kits seem to be if you can get consistent results in net R"s without load fade. If you get a lot of fade with your setup that simply equaled heat as well as a slower responding vehicle. It also seems to handicap your backshift. You can test this by racing heads up with a test sled full tilt for 5 seconds and then both sleds completely let out for 3 seconds...then hammer down again. You'll see the pull of a good setup come back much more aggressively while the other setup takes a longer duration to start pulling back to full RPM. It's very difficult to scientifically test (so we don't ever report distances or lengths) but it's there and the results and benefits of performance for mtn riding are telling. Thanks for your report.
Ummmm....Don't usually have to turn out....Haha just kidding, On steep n deep pulls this past month in the cascades with snow over the windshield, I would be right at 46-47mph track speed and about 8000 on the tach at around 5-6000' elevation, in less than 1.5 ft and firmer snow I am 8100-8150 on tach and 1-2mph faster on track speed unless snow is really wet. These readings are all off looking at tach, I have not done the recorder yet because once set in on the climb the guage was holding these numbers spot on and not jumping around so have not felt the need to run the recorder. I say I'm gonna every ride but end up not doing it. These numbers are the same from my buddies pro that is set up virtually the same, the only differance is I have a cut track and he doesn't, but I also out weigh him by almost a hundred pounds yet I can go everywhere he can, he keeps threatining to cut his track also to gain the advantage again. I keep waiting to pick him up one of these mornings and see a 174-3'" on his, I'm sure that is why he hasn't cut his so he can sale the track.So what kind of track speeds were you guys pulling in the steep and deep with the MDS weights. Snow varies a little but what did the tack say on a vertical climb right before turnout. Thanks
Went up yesterday with 100/340 spring, stock gears back in and solid button head screw with washer in tip (67.4?).
I am still flashing 8350, then goes to 8,250 and stays without flutter. I am also still 3/4" from full shift on the primary.
I just can't seem to get my rpm down. I guess I will keep throwing weight at it but why is mine different from you guy's?
I am running Carl's helix, trimmed track and avid drivers as well, suggestions?
How did you like the 100/340 spring? What RPM does your sled engage at now? I had the same problem you are having with the RPM and I just kept adding weight to the tip and that finally brought it down to 8050 or so... I don't have the Carl's helix though!
In response to last several posts above, I don't know how to multi quote, I too was over revving but with stock setup. I could easily reach 8450-8550 without hitting limiter and my buddy was getting limiter around 8400???? Don't know why that is. After installing head, can, MDS weights at 67.3 grams for a 4-7k primary riding area. My engagement was 4700 with stock spring. I was pulling 8250-8300 also. I installed delrins, a 120-340 spring and engagement dropped to 4150-4200 and top rpm down to 8100 give or take depending on snow. I hit rev limiter alot on the trail and when in less than 1.5-2ft of fresh especially if unloading on a climb due to a bump but this is where I wanted to be so that on the really deep days when you want your sled to pull like a mule on crack it does, and just keeps pulling. For those of you that are high, take a look at your snow conditions, this could be the reason, it's kinda of a give and take. Also I have not seen this setup yet with Carls secondary, that was my next add on to toy with, could definately be some issues with having to add some more weight. Talk with steve bout putting another solid in the inner hole.
I have a 100/340 spring but have not tried it, it sounds like my thoughts on it have proved themselves, I figured engagement would drop to around 3800, the other factor to consider here is that with a softer bottom you also have a softer mid, this is why you see 8350 right out of the gate and settle to 8250. These weights shift out so fast and with a lot of force and the 100/340 spring can't keep up and gets mushed then pushes back. I believe the 120/340 is the way to go.
I have had no problems with low end bog or excessive trenching, actually one of my favorite things about these weights is to be able to get off the gas or even stop in the trees when it;s deep and get going again, I know alot of this is the chasis but the clutching doesn't hurt it.
These were designed for a stock machine, but without to much playing around with set up they are in my opinion easily dialed for individual rider, weight, style, elevation, conditions, and mesh real nice with other accessories, just takes a little fiddling with, each sled becomes it's own lab rat, step back, think outside the box and take a look at what is happening with your sled and what would remedy the problem and it will all come in line. Let er RIP!!!!![]()
You can do it on the mountain, you need a screwdriver to pry open at first then a wrench to pry open the rest of the way and insert a socket of correct length to hold open or use a c-bracket(hand made) to hold it, but it has to be all the way open. I have removed the cover too and it is almost as fast and a little safer on the fingers. With a socket or ratcheting wrench remove 3 of the 6 bolts completely and remove the other 3 evenly, once it's halfway off you can actually hold it with one hand and run them out, just repeat process on install, be sure to line up the "x" on outer cover with the one on the primary, I'm sure you knew this but had to say it. No more than "pinky finger torque" on install, around 8-10lbs or so, don't remember for sure, or you can break them and that's a pain. I have a cut down t-handle hex wrench and ground down end wrench to remove the ramp pins. Hope this helps.Okay, my snowconditions may be the reason it revs so high.... I wonder how do you adjust your mds weights on the mountain? I found out that I have to remove clutch cover to get them out for adjustment? am i right? the stock weights I could pull out by using large screwdriver to bend my primary open... thanks
