what gearing are you running?
I need to add weight after the head install and those MDS sound like the ticket.
If ya need 8000 RPM adding a little weight to these arms is very simple, interesting thing about reading the RPM on our tacks is making sure its the real thing.
The MDS's are working great, much more responsive then the 10 series.
Have been playing around with gearing, springs , and helix's and have made significant gains....the adjustability of the MDS is nice.
Clutch temps stock were very hot and was able to junk a belt rather easily....now the clutches are barely warm after many long pulls!
HUGE improvement from stock!
Stock Gearing, havn't seen a need to change for where I ride. If your running a PA head(13.1) I would recommend having Steve set you up at 66.8, if you have cut your track then 67.3, this combo is ripping for me in the 4-7K range in the deepest of snow, have 0 complaints. Ephrata Farmer and I have the 67.3 and two other buds have the 66.8, the added weight was a plus after cutting my track to compensate for increased rpm and less engine load.what gearing are you running?
Second that. The Rooster Built Pro is dialed!! Could not believe how well it is running. Amazing what just being properly clutched and geared can do for a sled.....
I'm also running the 048 cat belt
800extreme yes BB's 64 grams. I rode at 9000 feet in the Trinities of Idaho yesterday with my setup. 8050 on a loaded pull in weird crust top sugar underneath snow. You would sink down about to your knee or mid thigh when breaking through. Same on the groomed trail. This is defying conventional clutching wisdom. I've never had a sled be so consistently dialed at so many alts and varying snow conditions. I was absolutely certain 64 grams which is my dead on dial in for McCall 6000-8000 would be under clutched at 9000ft 20* and lose snow. NOPE
I thought you were running the 046 cat belt...?
I am running the MDS weigths and have them set up with the following:
Tip=hollow button head and flat washer.
mid=1/4-28 setscrew 1/4" lg.
Mine runs 8,250-8,300 on long pulls and sure feels strong out of the hole all the way to full tilt.
I would like to know what others have loaded the MDS with for weight?
