Last I check it takes flyweights and a drive spring in the drive and a spring and helix in the driven to complete the setup.... If you were reading my post carefully I was talking only about flyweights as they relate to peak rpm.
If your sled can't hit peak rpm there's a good chance your flyweights are to heavy .... If your over reving there a good chance your flyweights are 2 lite.
MDS & SLP MTX flyweights are heavy IMO
DPG
Wrong again, you have to have the complete setup. If you put a 50* helix in and dropped weight to hit rpm you will never have any power even if you do achieve rpm.
Mds and mtx weights are heavy for a reason, they apply more power to the track.
I have seen as much as 9mph track speed changes with mds weights, yet both clutch setups pulled the exact same rpm in a climb.
Yet mds pulled more speed and flew past the high mark of the other setup.
As I said, there is a big difference in applied centrifugal weight vs actual weight.
